Got the car safety checked for the road. Front pads and roters only. Very good. The mandatory emisions test passed the CO but failed on the NO. I read the brochure on NO and it points to a possible egr or convertor.
I called my brother in law ( a very reputable porsche audi mechanic) and explained this. I asked him about putting the "ahem" additive to get it to pass. He said that it wouldn't help that they are going to find a bad cat. It won't be the egr and the motors not carboned up.
Is he just about right on there? The cars been in storage for the winter,( 3 months) and is running beautifully. the motor only has 30k on it. It has stabil in the fuel which is reasonably fresh. He says all that should be ok and it will be a problem with a cat. Any comments or anyone else have this issue?
Its a 92 LT1. I just went back over to the garage and took the car out and hammered it bigtime up and down the freeway. Luckily I didn't get caught I musta been doing over 100mph in places. Put a hot of heat in the convertors and then took it back to get retested. Hopefully it will pass now.
All you guys still in storage get em out! I had a smile so wide I near cracked my face open. Car was just bitchin fast and I blew off pretty quick a rice burner that tried me on throttle roll on. I just snicked it down into fourth and rolled it on and away.
Think i may need a clutch soon though. She's a bit whinny when its not depressed at a stoplight. I was very happy with all the guage readings too.
if you have bad NOX, I would check the EGR side of things. There is a pipe that goes from the right exhaust manifold to the intake. That pipe CAN crack at the brazed joint. If that is cracked, NOX becomes hit and miss...
Don't blame the cat until you are sure.
And from where I sit, I am still not sure that NOX is effected by the cat. I need to do research.
Great stuff and thank you. I'm still hoping its because the car was sitting for three months. Lot of water vapour came out the exhaust pipes for a bit. It should be clean now. I hope they know enough to test it hot.
If not I'll check that pipe. They already found a cracked vacuum line and replaced that.
I agree that he should check the EGR first.
The chemicals in the substrate inside the cat removes oxygen from the NOX and turns it into nitrogen and oxygen. It does break down the NOX
I assumed that the EGR was ok because he said nothing about the SES light being on.
Timing and EGR and the operating temps have big effects on nox.
Greg N
