Vacuum check valve question
Old Mar 23, 2006 | 10:04 AM
Sliding's Avatar
Sliding
Default Vacuum check valve question
I've broken a vacuum check valve on power brakes booster( that's part name from manual ).
Is this only a plastic reduction ( on pics ) or should that really be a valve?
Old Mar 23, 2006 | 10:21 AM
conv90's Avatar
conv90
You broke it installing the SR?
Old Mar 23, 2006 | 10:50 AM
Sliding's Avatar
Sliding
Yes. Actually, I broke it while removing stock intake. :o
Old Mar 23, 2006 | 11:57 AM
aminnich's Avatar
aminnich
It is a check valve so you don't lose vacuum from the booster under low vacuum/ low rpms. You will want to replace it with check valve, not a reducer.
Old Mar 24, 2006 | 04:32 AM
Sliding's Avatar
Sliding
O.K. Thank you.
To Vacuum check valve question
