starting probs
Old Mar 23, 2006 | 03:18 PM
uk vet's Avatar
uk vet
Default starting probs
Just put in a new battery in my 92. Charged it to show over 13 volts with a meter and when i connect it to the car the dash showed 12.8 but i still only got a click and the voltage goes to 12.2 ,does anybody have any ideas please ?
Old Mar 23, 2006 | 03:20 PM
Jerris's Avatar
Jerris
Sounds like you have a burnt out starter.
Old Mar 23, 2006 | 03:22 PM
RRT vette's Avatar
RRT vette
Where there any problems before the new battery? That is enough volts to turn the engine over. Have you checked the connections to the starter. Might even want to tap it with a hammer to unfreeze it.
Old Mar 23, 2006 | 03:25 PM
dwestsr's Avatar
dwestsr
It's normal to see acouple tenths difference in voltage between a meter reading directly on the battery and that of the dash voltmeter. It sounds like you have a poor ground or the starter is bad, most likely the solenoid. One thing to try is to tap the starter smartly with a hammer and see if it turns over . if it does , for sure you have a bad solenoid although that crude test is not totally conclusive.
Old Mar 23, 2006 | 03:41 PM
uk vet's Avatar
uk vet
It has been laid up and not started for about 12 weeks but before that there were no problems
Old Mar 23, 2006 | 11:18 PM
jfb's Avatar
jfb
The starter solenoid causes the starter motor pinion gear to engage the flywheel ring gear at the end of its stroke and also at the end of its stroke, two copper contacts make connection to supply current to run the starter motor. These contacts get pitted and burned and eventually make poor or no connection and you get the symptom you have, you can hear the starter solenoid click but the starter won't crank. You can replace the starter or take the starter to an auto electric shop and have them replace the contacts, or do it yourself. Tomorrow I get my 87 back for the same symptom you have!
Old Mar 24, 2006 | 06:31 AM
rons85's Avatar
rons85
Just to point out that a fully charged "12 volt", 6 cell, lead acid battery should be showing 13.2 (the exact, perfectly correct, answer is 13.2 and change) volts. It's 2.20v and something per cell, in a perfect world. All a charger does is "float" a voltage across the battery terminals that is Higher than the normal fully charged amount. If you can't get the battery up to 13.2v (and it should be showing somewhat higher than that right off the charger...) after all that time on the charger - check the battery for a bad cell...
To starting probs
