Hesitation
Old Mar 23, 2006 | 03:50 PM
rickneworleansla's Avatar
rickneworleansla
Default Hesitation
My car recently started to hesitate or bog down when pushing the throttle 1/2 to 3/4 of the way down. This only seems to happen when first started and the engine temp is below 150 degrees. Any ideas?
Old Mar 23, 2006 | 04:40 PM
RRT vette's Avatar
RRT vette
I looked in my 86 FSM and it says in this order for hesitation, sag, or stumble. Little different for 95
check fuel pressure (should be 42 to 47) or for LT1
air leaks between MAF and TB
Spark plugs and wires
Ignition timing
Alternator output
Injector balance
IMO
p.s. I had a nissan rice burner that fried a diode in the alternator when I pulled too hard on the throttle passing cars.
Old Mar 23, 2006 | 06:25 PM
rickneworleansla
Thanks, I'll check there first. Anyone else?
Old Mar 23, 2006 | 06:34 PM
Jerris's Avatar
Jerris
Test your TPS switch with an analog ohmmeter for burnt out sections at the 1/2 and 3/4 positions.
Old Mar 23, 2006 | 11:09 PM
Vett-eight-nine's Avatar
Vett-eight-nine
What's a good price to pay for a new tps ('89) and where?
Old Mar 24, 2006 | 12:30 PM
Diesel68's Avatar
Diesel68
I had the same problem. As the car warmed up, and after the computer went into closed loop, everything was fine.
Take off your MAF sensor and clean it using electronic cleaner. It is a cheap first fix.
Old Mar 24, 2006 | 01:59 PM
94vette1's Avatar
94vette1
did you get it fixed??? having the same problem (50% of the time)
Old Apr 6, 2006 | 06:34 PM
rickneworleansla
Not yet fixed. I'm changing my fuel filter and injectors this weekend. I'll keep troubleshooting from there.
Old Apr 6, 2006 | 10:22 PM
Biff Buyer's Avatar
Biff Buyer
ive noticed alot of people have this problem, just throwing money at it doesnt seem to ever solve anything though...
Old Apr 7, 2006 | 09:00 AM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
My 94 has the same problem. Once it warms up everything seems to be fine. I have changed the plugs, cleaned the MAF, changed fuel filter, but haven't checked the TPS. I guess I'll do that next.
Old Apr 8, 2006 | 01:15 PM
rickneworleansla
How do I check the TPS?
Old Apr 8, 2006 | 04:22 PM
RRT vette's Avatar
RRT vette
You will need a voltmeter. Key on, not running, the TPS will need to be connected to get volts. On my 86 (probably different for LT1), probe the black wire (ground), and dark blue wire (ecm signal) to get the volts, then loosen the two bolts holding it on. And again numbers could be different on your, someone here might correct me. The volts should read 0.54v at closed throttle and 4.00v at WOT. Adjust the TPS to these numbers and your good to go with the TPS.
Old Apr 8, 2006 | 09:03 PM
dbaker's Avatar
dbaker
I replaced my Cap,Rotor,Coil,& Ig Control Module today,used all GM stuff from the great folks at Superior Chevrolet ( www.superchevyperformance.com).
NGK coppers lighted by Moroso 8mm Wires.
The old 85 has never run better.No hesitation and better feel from the SOTP dyno.
\db2
Carolina
To Hesitation
