DataMaster Log
Old Mar 24, 2006 | 12:19 PM
rtracy's Avatar
rtracy
Default DataMaster Log
Hello! Im trying to tune a 95 lt1 Vette. The tune I have now is from pcmforless. I had reason to believe that it was rich do to the eye burnning exhaust and the black puff of smoke out the back when I get on it so I decided to get some tunning software.
Anyway, I dataloged my car at idle for about 15min. and was woundering if I could get someone to take a look at it with me? If I am looking at it correctly it is running rich. Here is what I have,
Fuel trim- cell 16 all the way threw the log.
LTerm- 108 to 122
STerm- 123 to 132
Knock counts- started right out at 1768 and stayed there.
O2mv- jumping from 102 to 850.
Spark advance- 26 to 30
Spark retard- 0.0 to 0.1
The spark retard didn't start til about 5min. into the log and it went from open to closed lope after the spark retard. Because of the LTerm counts being 108 to 122 I am thinking that it is burning rich. So am I even close and if so how can I change this?
Thanks, Ray
Old Mar 24, 2006 | 12:28 PM
STL94LT1's Avatar
STL94LT1
Can't you send your datalog to pcmperf, and they'll make the changes?
Or if you have Tunercat/LT1 edit, you can run the datalog through VEMaster and it will make the corrections.
Old Mar 25, 2006 | 09:21 AM
rtracy's Avatar
rtracy
Thanks for the reply. If I was to run my loged run threw vemaster it will make the corrections for me? Wow, that sounds easy. I have never heard of this. Is this true?
If Morley is reading this, I don't know what happen to you helping me out with my datalog but when you wouldn't return any of my e-mail I took it as though you didn't want to help.
Old Mar 25, 2006 | 01:03 PM
Morley's Avatar
Morley
I sent you a PM about your log. You need to see if you are universally rich (in all fuel trim cells) or just a couple (or one) and go from there.
Old Mar 25, 2006 | 05:44 PM
larrynash's Avatar
larrynash
Default Same problem
I have the same year car and engine with the same problem. Today I recorded a datamaster file in acceleration. LT is very lean over 2000 Rpms, ST trim is ideal (over 900 mv on the O2 sensors and 149 LTerm counts). I'm changeing my fuel filter. Fuel pressure is fine at ideal but I will check under acceleration. What would cause LT to be out of wack?
Last week I ran some Seafoam through without success. Any other ideas?
Old Mar 25, 2006 | 08:29 PM
Morley's Avatar
Morley
You have a mismatch there...lean BLM (149) and very rich O2 (900mv)
With the int being in the 128 range that tells you that the ECM is able to compensate for the lean condition.
This is a stock engine? I would start looking for small vacuum leaks if it is stock...cracked plastic lines, PCV hose old and leaking at the connections, PCV valve leaking, etc.
Old Mar 25, 2006 | 08:45 PM
larrynash's Avatar
larrynash
Default Lean Condition
Below 2000 Rpms and low airflow (30 gm/sec), everything is fine. LT and ST is around 127. Wouldn't a vacuum leak show itself most at low RPMs? If the problem is fixed, is there any way to clear the LT? How long until things look normal on its own if fixed?
Old Mar 25, 2006 | 09:25 PM
rtracy's Avatar
rtracy
I got your PM and sent one back. I will get you that log tomorrow and send it to you. Thanks.
Old Mar 26, 2006 | 10:40 AM
larrynash's Avatar
larrynash
This is a totally stock engine. There doesn't seem to be a vacuum leak.
Old Mar 26, 2006 | 02:30 PM
Morley's Avatar
Morley
"long term" is a relative term, in ECM speak it means a couple of seconds. The ECM is constantly learning and compensating for changes in the way the engine is running.
Old Mar 28, 2006 | 06:55 AM
larrynash's Avatar
larrynash
Default Long Term Fuel Trim
When I say "long term" I am speaking about the long term fuel trim or BLM. I disconnected the battery to clear the memory. The problem still exists.
Old Mar 28, 2006 | 01:09 PM
Morley's Avatar
Morley
So was I.
To DataMaster Log
