New Taylor plug wires - strange question????
Old Aug 16, 2001 | 03:35 AM
Larrym96815's Avatar
Larrym96815
Default New Taylor plug wires - strange question????
I put on my new plug wires (from Chris of course) and went for about a 15 mile ride tonight. I changed nothing else other than the plug wires yet my idle is about 300 rpms more than before. The old wires were original with 34K miles. Does this make any sense or sound possible? Strange??? :eek:
Aloha,
Larry
[Modified by Larry Mackey, 1:36 AM 8/16/2001]
Old Aug 16, 2001 | 03:38 AM
GlockLT4's Avatar
GlockLT4
Default Re: New Taylor plug wires - strange question???? (Larry Mackey)
Did you upgrade from the stock ones to these? You might want to get a better coil.
Old Aug 16, 2001 | 03:50 AM
Larrym96815
Default Re: New Taylor plug wires - strange question???? (Glock'94)
Glock,
Only change was new Taylor wires. Could this cause a different idle speed? Wouldn't the IAC compensate for any changes or would it take a few miles to learns or ??????
Larry
Old Aug 16, 2001 | 10:22 AM
traxx1's Avatar
traxx1
I put new taylors on 2 months ago and nothing changed except I didn't have a light show under the hood at night, your IAC should be compensating for the faster idel, check the connection there or maybe clean it and see what happens.
:seeya traxx1 :seeya
Old Aug 16, 2001 | 01:26 PM
Chris@SD's Avatar
Chris@SD
Who is Chris??? ;)
You might want to reset your computer by unplugging the battery. That and clean out the IAC.
Good Luck! You Honolulu guys are GREAT! It must be the weather and scenery over there.
Old Aug 16, 2001 | 02:03 PM
Larrym96815
Default Re: New Taylor plug wires - strange question???? (2FST4U)
Let's see who is Chris?? :rolleyes:
Thanks again.
Larry
Old Aug 16, 2001 | 03:22 PM
BobMachus's Avatar
BobMachus
If your old wires were a mess and not delivering much spark someone may have fiddle with your idle speed screw to keep it running. Then when new wires started delivering good spark to the plugs, the idle speed went up. Is the little AL cap on the back of the idle speed stop screw off or damaged? Just a thought, I'm really not a pro at this.
Old Aug 16, 2001 | 05:32 PM
Larrym96815
Default Re: New Taylor plug wires - strange question???? (BobMachus)
Someone? I'll bet it was my wife! :D
Larry
Old Aug 17, 2001 | 04:14 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You didn't knock a vacuum line off somewhere did you ?
Old Aug 17, 2001 | 02:15 PM
Larrym96815
Default Re: New Taylor plug wires - strange question???? (AquaMetallic94LT1)
Good thought, I will check the vacuum lines. After all, no big deal, there is only about 100 of them right? :D
Larry
To New Taylor plug wires - strange question????
