Where is the oil temp sensor located?
Old Aug 16, 2001 | 04:35 AM
A's Avatar
A
Default Where is the oil temp sensor located?
I just happened to notice that in the 94 degree florida sun running 195 degree coolant temp, my oil temp was "LO"...
Old Aug 16, 2001 | 04:41 AM
NoWorries's Avatar
NoWorries
Default Re: Where is the oil temp sensor located? (A)
Right over top of the oil filter.
Right over top of the temp sensor is your block/transmission ground...just FYIW, I thought it was interesting how many systems are grounded at that point, at least a dozen.
Anyhow, right over top of the oil filter, pretty easy to change.
Old Aug 16, 2001 | 04:49 AM
A's Avatar
A
Default Re: Where is the oil temp sensor located? (NoWorries)
hmmmm... is it a piece that's easy to break while...i don't know...changing spark plugs, perhaps? :bb
{EDIT} Ohhh oil filTer... not oil FILLER and ABOVE NOT BELOW... ahh... man it's late :crazy:
[Modified by A, 2:50 AM 8/16/2001]
Old Aug 16, 2001 | 05:21 AM
JoBy's Avatar
JoBy
To Where is the oil temp sensor located?
