checking pickup coil ?
Old Mar 27, 2006 | 10:19 AM
rick lambert's Avatar
rick lambert
Default checking pickup coil ?
In my quest I've decide to check my pickup coil-but I need help. Part 2 in FSM I can understand-500-1500 ohm range. Part 1 is where I'm confused.While using an OHM meter it says it should read infinite at all times-what does that mean-and what would the OHM meter show-does it mean the meter would peg on the high side?
Old Mar 27, 2006 | 10:48 AM
kalister1's Avatar
kalister1
An infinite reading on the ohm meter is what you see when you hold both leads out in the air, not touching each other. When you touch the 2 leads together you will see 0 (ZERO) ohms resistance, or sometimes you might see 2 or 3 ohms depending on the quality of the meter and leads. Older meters that use a needle (Analog Gauge) have a way of adjusting the 0 (ZERO) ohm reading.
Old Mar 27, 2006 | 10:55 AM
rick lambert
When I hold them apart in the air I get 0L, is that what an infinte reading looks like? touched they do read 0.
Old Mar 27, 2006 | 10:59 AM
kalister1's Avatar
kalister1
Yes the OL you see is an infinite resistance reading. That is th emost the meter can return at that setting. If you hold 1 lead in each hand between thumb and finger you should see your body resistance, several meg ohms?
Old Mar 27, 2006 | 11:17 AM
rick lambert
Thanks kalister1, you guys won't make an electrician out of me-but man I'm learning alot of trouble shooting tecniques and getting used to my ohm meter now.
Old Mar 27, 2006 | 12:09 PM
Morley's Avatar
Morley
BTW, the OL displayed on the meter means "open line", their way of saying that the circuit is open.
Old Mar 27, 2006 | 12:49 PM
rick lambert
OK, thanks . If you were checking a circuit, a wire from one connection to another and there was a break in the wire somewhere-would that show up as 0L then? you guys may make a half a$$ed electrician out me yet.
Old Mar 27, 2006 | 01:34 PM
kalister1's Avatar
kalister1
Yes, a broken wire would read OL, that would be just like holding the leads apart. Some bad connections that are corroded or have broken strands will read a high resistance, 1000 or more ohms. Sometimes while the meter is hooked up you can wigle the wires and watch the resistance change, that would be an indication of a poor connection.
Old Mar 27, 2006 | 01:58 PM
rick lambert
Just read the picup coil.Test 1 shows putting one wire from the meter to ground and the other in_I'll call it terminal A, the reading should be infinite-it was. Test 2 shows putting both leads from the meter into
both terminals A & B, the test says it should read between 500-1500 ohm range-mine read .791 does that indicate the pickup coil is weak or bad? secondly, if I need to replace the pickup coil, how the heck do you get that C washer off ? or do you have to pull the distributor, drive out the pin from the shaft. thanks guys
Old Mar 27, 2006 | 02:29 PM
kalister1's Avatar
kalister1
I cannot help with replacing the coil. Check the SCALE on the meter. If you see a K (k) in the display that means you are in the K (KILO)(1000) ohm range, so .791 K = 791 ohms. Read the owners manual for the meter if you have it. Some meters are auto-scaling and some are set manually.
Old Mar 27, 2006 | 02:51 PM
rick lambert
Yep, it was in the K, so I guess that means ok right?
Old Mar 27, 2006 | 02:57 PM
kalister1's Avatar
kalister1
Yes .791 K = 791 ohms, that's a good reading.
.791 * 1000 = 791
Old Mar 27, 2006 | 07:11 PM
rick lambert
For many reasons i HAD A HARD TIME SLEEPING LAST NIGHT-THIS ONE OF THEM. I was thinking-did I put the right wire from the coil in the right position-so, first I checked the pickup coil-thanks guys-it appears to be fine. Next I pulled off the coil cover-SH*t, when I installed it
the battery wire got crimped and looked like it was arcing-back to Autozone,felt like and feel like a friggin idiot-but all was not lost, that fixed the digi scramble I still lose my instant mpg and my range, and I still think the miss is there, I posted asking about ECM symtoms and hippy posted almost my symtoms-don't know and haven't finished under the car or checked for balance yet-but at least the digi is workig almost great again.Keep u posted.Update, hooked up my timing light checked each plug-getting good fire on each.Checked my timing-after reading instructions on radiator-just a note-it said nothing about putting it in D, anyhow it was holding right at 8-where I had set it.
To checking pickup coil ?
