"Help" front engine clearence after installation
Old Mar 28, 2006 | 08:29 AM
The Bus's Avatar
The Bus
Default "Help" front engine clearence after installation
I removed the engine and tranny. Now with everything installed the front of the engine is tilted downward enough that the damper will not go on. It's a 91 with solid motor mounts. Can the "C" beam be shimed to the tilt the engine down or is there something I'm overlooking??
