Missing Bolts!
Old Mar 28, 2006 | 09:43 AM
Demonic85's Avatar
Demonic85
Default Missing Bolts!
I was under the hood yesterday replacing some worn out vacuum lines and noticed that my intake manifold is missing a bolt. The previous owner must have taken the manifold off and forgot a bolt, grrrr. So I have a few questions. Will one missing bolt hurt the engine in any way? My local parts store has a bolt kit, but is it a wise idea to get bolts from them? I'm worried about fit issues and whether or not its made out of the original material.
Old Mar 28, 2006 | 09:46 AM
Jerris's Avatar
Jerris
Replace the bolt, if it is not causing a vacium leak now it will in the future. Take out one of the other bolts and take it to the hardware store and ask for another the same size and grade. Dont forget the washer.
Old Mar 28, 2006 | 09:54 AM
Demonic85's Avatar
Demonic85
Yeah I think it is causing a vacuum leak, because after I fixed my vacuum hoses I still have an idle problem. Do you know what size the bolt and washer are? I'm thinking about just taking apart the top half of the engine and replacing all the gaskets too.
To Missing Bolts!
