Cranks...Idles...Shuts Down!
Old Mar 29, 2006 | 07:00 PM
MostWanted's Avatar
MostWanted
Default Cranks...Idles...Shuts Down!
It does just what the title says. After I finally figured out that I had two wires crossed...everything seemed fine. The lights on the dash acted as they should and she fired right up. After about 5 seconds it shut down...so I fired it back up...same thing. This all happened after I changed my heater core and had to unhook all those wires under the dash. Anybody have any ideas what is going on? Keep in mind that the dash is still out along with the console. Any help will be appreciated.
Old Mar 29, 2006 | 07:33 PM
RRT vette's Avatar
RRT vette
Check fuel pressure! What year?
Old Mar 29, 2006 | 08:21 PM
MostWanted's Avatar
MostWanted
It's a 1996. It is getting fuel as far as I can tell. I did check the codes and am getting a:
7. ERR
9. ERR
A. ERR
Anyone know what this is?
Old Mar 30, 2006 | 11:09 AM
Jerris's Avatar
Jerris
The 3 ERR messages show that the CCM is out or more likely, you have dislodged the plug in connector. Check the connector to the CCM (BCM)
Old Mar 30, 2006 | 04:34 PM
MostWanted's Avatar
MostWanted
Could someone please point me in the direction of the location of the CCM in my 96 Vette. The Chilton Manual sucks when it comes to that stuff. I keep hearing about PCM, ECM, CCM, BCM, etc. All of it is pretty confusing when I don't even know which ones my year model vette has. I do know I have a PCM because I have had it sent off for reprogramming...that is an easy one. I will gladly check the connections on my CCM if I know where to check. A little help here please. Thanks.
To Cranks...Idles...Shuts Down!
