I'm a stupid...
...I'm much more than stupid... I'm really stupid.
Yesterday I was removing a Roller rocker.
When I was putting the nut on the stud to use the manual spring compressor ...the nut fall down in the engine bay...
I can't find it
I searched everywhere .... nothing
I felt a noise of metal (I tought : " yes it's near the hooker headers or near the starter.." Nothing! OK it wil be in the floor..
(my garage is not so clean :bb ... ) but Nothing!
So after 3 hours of searching I'm considering to buy new nuts for the rockers.
(one day I'll find it just when I will not need anymore...
)My roller rockers are Comp Cams Pro Magnum 1.6 with 3/8 studs not self aligning
part number CCA-1302-16
Whick kind of nuts I need? this part? CCA-4601-16
Im considering also to change to 7/16 studs. Could i buy just the flat or raised 7/16 guideplates and 7/16 studs and the right nuts or the rockers i have itself are made only for 3/8 studs?
-Beppe- (the stupid one with the best collection of nuts and bolts in the engine bay..)
something you might be able to do to upgrade and not have as much cost as buying 7/16 rockers is to buy a rocker stud girdle- since you already have to buy new rocker locks. a girdle might not fit though depending on what you have for valve covers.
I almost never got it out after i found it, some how it set up a wierd harmonics at about 3500 rpm and sounded like the motor was coming apart.
Good luck with it, and you are not the first or last that this has happened to.
your not alone Charley, I was testing my pickup coil held in by three friggin screws which I set on the plenum, went to move my drop cord and bye-bye, didn't hit the floor (clean garage), swept the entire engine with my mech. mag, went and bougth a new pickup coil-$19. for three screws-didn't even get kissed
well, I do have a new PU coil when ever I need it-but-call me stupid whatever, so you're not alone.
Oh yeah, if any one needs an AIR pump pulley spacer, let me know.
I think it is a test of some sort by space aliens!
I try not to let it bother me. :o
