Cam Experts:Dual v single pattern cam?
As the more performance minded of us are running headers , upgraded exhaust and / or better heads what is the advantage of a dual pattern cam over single pattern other than to bleed off some bottom end torque?
I realise most of the popular L98 / LTX cams have more exh duration but some such as my ZZ4 cam have much more exh lift (.470 / .510) where as the Hot cam ( a proven runner) is .528 on both.
With a upgraded exhaust system it would appear to me that one would be running the risk of over scavenging the engine in extreme cases.
Question.
What are going to be the different characteristics of the same engine with a relatively "balanced" cam such as the hot cam or with one with more exh event (lift x duration)?
Was just seeking opinions on engine behaviour with the two types.
Will one give say, more torque over the other at a certain rev range?
Will one give more Hp ?
Etc
Higher compression with free flowing exhaust probably likes a single pattern. Larger displacement with larger exhaust may like a single pattern. High RPM, with appropriate gearing, may favor the single pattern. The more 'racecar like' you make it, the more you need to consider the single pattern cam.
Remember that LSA selection, installed positioning, lifter/camshaft type, and staggered rocker ratios are all useful techniques for optimizing a bigger cam and extracting a little extra power, in some cases, without sacrificing street manners or driveability.
Very small difference. Blubbering is more like crying though. Like when you forgot Valentines day or something pathetic like that.
I just got home from shooting pool so I don't feel too pathetic.
Now I'm just trying to spread some "joy" around.
What are going to be the different characteristics of the same engine with a relatively "balanced" cam such as the hot cam or with one with more exh event (lift x duration)?[/QUOTE]
I consider the Hot Cam to be dual pattern because of its 218/228 duration @ .050". The fact that is has the same I and E lifts reflects on its intended design as a 'match' for the LT4 head, which does have a higher exhaust flow peak, but has almost a 80% E to I flow ratio. Any less intake lift would be underutilizing the LT4 head, and any more exhaust lift would require more valvespring and/or reduce reliability without enough increase in power to warrant this 'trouble'. I don't believe you would see much more power if you raised the Hot Cam's exhaust lift UNLESS you were to increase compression, or increase cubes, WITHOUT further improvements to your exhaust system.
I went through the same type of analysis. When I first put on my TFS 23d heads, I used a split pattern, 264/270 & 112LCA Comp Roller on my Xfire. I read an article by Vizard on cam selection and weas intrigued. So I sent my head flow specs to Motors and Machine to see if I was leaving any HP on the table. I had measured static compression and it was over 200psi/cylinder. This had me suspecting that I was losing something due to pumping losses and needed some more overlap. The spec came back suggesting that I could use a single pattern cam. So I installed one with 10d more overlap. Its a 270/270 with a 108 LCA. My 1/4 mile dropped by about .4ths. The M&M analysis was worth every penny of the $40 I spent.
My original interest in the subject can about from whether I could squeeze any more power from my 95K L98 , basically a ZZ4 spec engine with siamised base , SLP runners and LTs .Has run 13.103 , looking for a 12.99.Am not looking to spend any money on this setup as building 383 race engine for drag only C4.
However on my parts shelf I have a hot cam and the 1.6 rockers ; others have run the hot cam with stock 113 heads with success so was looking to see if I would see any improvement with a rocker change on the intake or the complete setup.
Engine pulls strong (1.84 / 60ft ) but still suffers lack of breath over 5000 , even with a 58mm.
Cam , manifold and headers have taken it from 13.9 to 13.1 but mph has only gone from 99 to 102 suggesting a lack of top end power.
ZZ4 cam is rated 355Hpp @5200 with a carb so with TPI am prob not far off cam peak.
Any thoughts?
My Xfire ran a 13.3 wih a 2.1 60' last October with the new cam and with 'some" tuning using a WB. The cam/head/headers change took my Xfire from 15.1 to 13.3. One thing I found was that the motor was running lean at top end so I went from 10psi to 20 psi FP. Remember I am talking about a Xfire with 80# injectors. That was also on street tires at 35psi. The low end torque makes it impossible to do anything but slip clutch at the line. A good portion of the issue building top end power has to do with the manifold you're using. Clearly I have made the decision of working with the limitations of the Xfire manifold. Knowing that, I looked to optimize the power I could generate in the sweet spot the manifold gives me. So I would never expect to have a power peak at 6500rpm using the m,anifold I am using. The TPI manifold isn't really much different from the Xfire in terms of the torque and HP peaks due to the runner lengths.
As for the heads, if you read Vizard's articles, the primary measurement for heads is the low lift flow numbers, not the high lift numbers. That has to do with overlap. The next key is the efficiency of the combustion chamber design.
Finally, tuning is an absolute to maximixe the changes. I'm hoping to see high 12's next time out.
I shall now concentrate on cam choice my race engine
4 bolt 383 , forged Scat internals ,10.7:1 ,LT1 manifold,TFS 195 heads. Street manners won't be a problem.
