Water Pump Failure Imminent?
Old Aug 16, 2001 | 11:12 PM
vanduker's Avatar
vanduker
Default Water Pump Failure Imminent?
I'm still fairly new to these cars. Is there an acceptable amount of leakage from the waterpump on the LT1/4 cars? After being parked for the night, mine has a single drop of coolant on the serpentine belt. Is this "normal" or do I need to get an electric pump on order?
Old Aug 16, 2001 | 11:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Water Pump Failure Imminent? (vanduker)
No coolant leakage is normal.
Old Aug 17, 2001 | 12:02 AM
crewzenLT4's Avatar
crewzenLT4
Get ready to replace your pump. Mine started that way. Then it was spraying coolant on the hood. I did it during the winter when I was able to take my time. The hardest part was getting the old gasket off the engine. :chevy
Old Aug 17, 2001 | 12:13 AM
Sully_Tex's Avatar
Sully_Tex
Default Re: Water Pump Failure Imminent? (crewzenLT4)
You might as well have the OptiSpark replaced as well once you have all taken apart. That will go right after the water pump. :mad
Old Aug 17, 2001 | 12:50 AM
Thud's Avatar
Thud
Default Re: Water Pump Failure Imminent? (1Sully)
If it's leaking, it's failing. There's nothing on the engine that's supposed to leak any coolant under normal circumstances!
Mine has a coolant leak somewhere, I can barely smell it when the engine's hot... but I can't figure out where it's coming from. And I just put a new pump on a year ago.
Old Aug 17, 2001 | 05:04 AM
GlockLT4's Avatar
GlockLT4
Yep.. should NEVER be a drop coming from the radiator. If there is, you have a problem.
Old Aug 17, 2001 | 08:40 AM
89 Bob L's Avatar
89 Bob L
Time for a new water pump. Replace the belt while you are at it.
Old Aug 17, 2001 | 02:50 PM
Camvette's Avatar
Camvette
Default Re: Water Pump Failure Imminent? (Thud)
Thud, it sounds likec you have a gasket going. If you smell coolent it is being burned away on a warm engine. I hope I'm wrong. :chevy
To Water Pump Failure Imminent?
