C4 Flame out
Old Mar 31, 2006 | 08:52 PM
Mastercraft's Avatar
Mastercraft
Default C4 Flame out
I have a 1993 vette and had the engine quit three time while driving today and restarted in netural all three times> Has not done it again today. Has anyone had this problem? I was wondering could it be the dist ir coil wires getting wet with oil leak?
Old Mar 31, 2006 | 09:18 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I had the same thing happen to my 85 and it was the ECM overheating. It would just kill the engine, usually at a stop light. It would re-start after just a few minutes and run just fine until it got hot again, also it never did it when the temps were below 65. I'm not saying this is your problem but if you can somehow keep the ECM cooler maybe the car will stop dying and you will have found the problem without spending any $$. Are there any codes set?
Old Mar 31, 2006 | 09:30 PM
RED92LT1's Avatar
RED92LT1
Fuel filter?
Old Mar 31, 2006 | 09:36 PM
Mastercraft
No codes and today it was over 90 degrees here the hottest since I've owned the car enging temp was 219.
Old Apr 1, 2006 | 10:35 AM
Midnight 85
I would get one of those plastic, sealed ice packs, freeze it then wrap it in an old t shirt or something like that. Place it against the ECM and take it for a spin, if it still dies then you'll have to keep looking. I'm not familiar with optisparks so maybe someone else can give you some more ideas. Hope this helps.
Old Apr 1, 2006 | 12:39 PM
jabez's Avatar
jabez
Probably not the Opti since it will feel like you are driving in an earthquake or not run at all if that was the case. You have a fuel problem? When was last time you replace fuel filter? Is it running fine when it is running? Pulling any codes?
Old Apr 1, 2006 | 01:00 PM
c4cruiser's Avatar
c4cruiser
The 93 ECM has an aluminum finned case so it should dissapate heat better than the earlier smooth steel versions. High underhood temps can be an issue with C4's but underhood temps usually kill the alternator. Your coolant temps at 219 is not bad considering the ambient air temps.
A bad Opti as mentioned, typically results in very rough running and sluggish performance. If there was oil in the Opti, I would think you would not be able to immediately re-start the motor.
I would look at a clogged fuel filter or even the possibility of the fuel pump stopping intermittently. Have the the fuel pressue checked; should be 45-48psi.
Old Apr 1, 2006 | 11:00 PM
Mastercraft
I think you may be right about the fuel filter since it has not quit again although today it sputtered then ran perfect and went like a bat out of hell. I went to the auto store and purchased a new fuel filter and will put it in first thing tomorrow. Thanks for the assistance.
Old Apr 1, 2006 | 11:05 PM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
make sure to get all of the gas out of the fuel line before replacing it, makes it alot easier, and cleaner too!
Old Apr 2, 2006 | 12:15 AM
Mastercraft
Great advice how do you get all the fuel out?
Old Apr 2, 2006 | 10:35 AM
Midnight 85
I sure hope you didn't pick up a Fram fuel filter. Guys here on the forum don't think too much about Fram oil filters but I had an issue with their fuel filters. My 1998 GMC Sierra with 350 engine was running bad and I just knew it had to be the fuel pump because I had just changed the filter a few days before. The price of a new pump scared he11 out of me so my NAPA man said to change the filter again. I was reluctant but went ahead and got a NAPA filter, went home and pulled the Fram out and the insides of the Fram had come apart and was stopping almost all the flow of gas.
As to how to get the fuel out of the line, just pull your fuel pump fuse and start the engine, it'll die in a few seconds. Try starting it a couple more times then go ahead and change the filter. You won't get all the gas out of the line but there won't be as much and it won't be under pressure. Don't forget to replace the fuse when you're done.
Old Apr 2, 2006 | 11:24 AM
Mastercraft
Thanks I will do that. By the way where exactly is the fuel filter on a 93 Vette. Is it on the passenger side and if so towards the front or back. I should probably use ramps either on the front wheels or rear.
Old Apr 2, 2006 | 11:41 AM
c4cruiser's Avatar
c4cruiser
The fuel filter is on the passenger side frame rail next to the catalytic converter. It is a real PITA to do and takes some time. The higher off the ground the better. Get some line wrenches to loosen the fittings. You do not want to round the heads off!!
You should relieve the fuel pressue before starting. It's best to have a near empty fuel tank too. Pull the fuel pump fuse and start the motor. Let it run till it dies and that should relieve the pressure.
Have a catch can ready when you loosen the line as there will some fuel spillage.
I don't know how good the Fram fuel filters are, but their oil filters are cheaply made and not worth using. I would go with a AC Delco filter or a WIX (NAPA) filter.
Old Apr 2, 2006 | 11:45 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Not to throw you off track but after the filter(which is a PIA) if it happens again look at the coil/ICM as a possible cause.I just had the same conditions but mine went totally south in 1 day
Old Apr 2, 2006 | 12:01 PM
jabez's Avatar
jabez
First time I changed a fuel filter I ended up with bloody hands soaked in gasoline The next time I had Jiffy Lube do it.
Old Apr 2, 2006 | 09:41 PM
Mastercraft
You were right even after running the engine for only a short time with the pump fuse pulled it stilled dripped, thanks to my oil drain pan I saved the floor but did get my hands soaked when I pulled it out. It did in fact correct the problem. It was so clogged I was not able to blow through the old filter.
Thanks for all your assistance.
PROBLEM SOLVED........
Old Apr 3, 2006 | 06:10 PM
RED92LT1's Avatar
RED92LT1
Nice ... glad to hear it was just a simple fix!
To C4 Flame out
