new problem with the '61 tpi
Old Apr 1, 2006 | 10:04 AM
bcartman2's Avatar
bcartman2
Default new problem with the '61 tpi
thanks for all the help with the timing, i have a new problem, the car starts and runs fine but if i turn it off it will not start again unless i diconnect one of the injectors. it does this even after only running for a min or two. all of the new injectors ohm out in the upper 15 ohm range, i think that is within spec. any ideas thanks
Old Apr 1, 2006 | 10:38 AM
rick lambert's Avatar
rick lambert
Yep, that's a good range. I know there new, but have tried starting it with the gas pedal floored? the injector your disconnecting-is it the same one each time? Maybe you should try a noid light on the injectors
and you probably should hook up a fuel pressure gauge too, if it bleeds down to quickly-that will answer the question.
Old Apr 1, 2006 | 02:20 PM
bcartman2's Avatar
bcartman2
the fuel psi. is at 40 when running, and goes up to 45 when the car is shut off, it stays there for at least an hour. i have unplugged four or five diffrent injectors with the same result. i cant test the injectors with the light because they work after the circuit has been broken.
Old Apr 1, 2006 | 02:28 PM
bogus's Avatar
bogus
You say that you "disconnect" one, but does this mean you disconnect and reconnect? Or disconnect and try to start it disconnected?
Either way, really, I would be sure that the system is properly grounded.
Did you have the ECM flashed to remove VATS?
Old Apr 1, 2006 | 02:42 PM
rick lambert
The pressure just about eliminates any leaky ones. Didn't understand your last sentence however. Not even sure it would be worth checking with the noid light-just in case though, I beleive their batch fired like my 87, you just plug in the noid light in each injector pigtail-crank and watch it flash. If I remember right this is an 85-right? they don't have the key pellet do they? Bogus might have a point about vats.
Old Apr 1, 2006 | 02:55 PM
bcartman2's Avatar
bcartman2
i am using an aftermarket prom and a painless harness, there shouldnt be any vats system active. i am checking grounds, could it also be a power problem holding the injectors in a powered state until i break the circuit by pulling one of the injector plugs.
Old Apr 1, 2006 | 03:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ohms at the injector doesn't mean much in my opinion, there's so many other things to go wrong.
I had some pissing a stream of fuel, some flowing nothing at all, and some working properly, but the ohms all checked out fine. None of them were stuck open however.
I think Scorp508 may have run across this problem, check with him..
To new problem with the '61 tpi
