Superram seal leak????
Old Apr 2, 2006 | 01:30 AM
nelson84's Avatar
nelson84
Default Superram seal leak????
How do you know if you have a seal leak? Can you hear it, or does the engine run ruff?
Old Apr 2, 2006 | 06:34 AM
The Bus's Avatar
The Bus
With the engine running take a hand held propane bottle/torch like you would use to solder copper pipe together and open the valve do not light it. With the engine running move the torch around all the joints between the parts and if the engine speeds up in a given area that's where you have a leak.
Old Apr 2, 2006 | 06:52 AM
goldeneye_vet's Avatar
goldeneye_vet
You could also use carb cleaner. Same thing as above, spray around the intake and if the engine speads up you have a leak.
To Superram seal leak????
