lt4 cam to lt1
Old Apr 2, 2006 | 11:32 PM
bigwave71's Avatar
bigwave71
Default lt4 cam to lt1
can i put a lt4 cam in my 93 lt1?
Old Apr 2, 2006 | 11:38 PM
MrNuke's Avatar
MrNuke
Wouldn't make a big enough difference to make it worth it..
Old Apr 2, 2006 | 11:47 PM
bigwave71's Avatar
bigwave71
i have the engine out being rebiult and i can get a good deal on a cam just wanted to make sure it would fit.
Old Apr 2, 2006 | 11:57 PM
ncChris's Avatar
ncChris
we did it on a 94 auto.. and used stock 1.5 rockers. With electric water pump the car ran 13.3s.. Use 1.6 rockers with taller springs.
The hot cam with new springs and roller 1.6 rockers would give you lots more pizzazz.
Old Apr 3, 2006 | 12:10 AM
Jay Axson's Avatar
Jay Axson
YA, if your going to swap cams, go for the LT4 hotcam. The kit is around $500. Includes cam, 1.6 roller rockers, springs, and retainers.
You will need to upgrade your chip to get it to idle properly.
Old Apr 3, 2006 | 12:37 AM
bigwave71's Avatar
bigwave71
i have 1.6 rollers and the lt4 springs in now.so i should have no problems with the timing chain bolting up? thanks for the replies.
Old Apr 3, 2006 | 04:19 PM
bigwave71's Avatar
bigwave71
ttt
Old Apr 3, 2006 | 05:29 PM
clf93lt1's Avatar
clf93lt1
i put lt4 hotcam kit in my 93,stock opti & timing set.no trouble with it yet.
Old Apr 3, 2006 | 05:31 PM
clf93lt1's Avatar
clf93lt1
you have to cut the pin down on the cam for the gen1 opti
Old Apr 4, 2006 | 03:29 AM
bigwave71's Avatar
bigwave71
ok thats what i was trying to find out. thanks for the info neighbor.
Old Apr 4, 2006 | 05:39 AM
93 ragtop's Avatar
93 ragtop
In case you didnt know, there is a difference between the LT4 cam and a LT4 hotcam. The LT4 cam was stock production on a LT4 and the lift and duration is almost the same as a LT1. The LT4 had 1.6 rockers where as the LT1 only came with the 1.5 rockers. This makes the cam seem bigger on a stock LT4.
Now if you are referring to the LT4 Hotcam, this was built by chevy as a offroad (non emissions cam) upgrade. A lot of us use it and it gives a healthy increase in power. It can be tuned to pass emissions, but GM did not have it tested so it is sold as off road use.
To lt4 cam to lt1
