Vibration- sometimes?
Old Aug 17, 2001 | 01:11 PM
89 Bob L's Avatar
89 Bob L
Default Vibration- sometimes?
I have an 89 coupe with new tires and rims (approx. 11 months old). I threw a weight and had the tires rebalanced. After several months I now have an intermittant shake, sometimes none, sometimes at approx. 40 mph, sometimes at 60 mph. The shake seems to come and go. Any ideas or suggestions? :confused:
Old Aug 17, 2001 | 01:45 PM
Camvette's Avatar
Camvette
Default Re: Vibration- sometimes? (89 Bob L)
Try checking your lugs. I've learned from experience to tighten the lugs myself after having the wheels removed by a shop for tires, shocks, brakes, etc.
Had the same type vibration on another car and 1 lug was gone and 2 were loose. :mad
Old Aug 17, 2001 | 05:30 PM
waccabuc's Avatar
waccabuc
Cruising
Change the shocks, I had the same problem with my 96 CE LT4 Bilstein shocks, replaced with koni sports. Problem is Gone. Seems there are a few cars out there with this problem which occurs during hot days, and under 50 miles per hour. Somethung about heat sensitive?
To Vibration- sometimes?
