hi guys,need some help/advise. have a 96 6spd. am havinfg a heck of a time with drivetrain vibration. when driving and geearing down will get a vibration when in 4th or 5th gears. only happens when clutch first engaged. had clutch and flywheel checked -all ok. any info would be a big help. was going to get highspeed license but have to fix 1st. thanks for any help
Do a search on the forum regarding your problem. I've been doing a lot of reading on a similar subject, which relates to a flywheel balance issue.
You may also want to add more detail to your post to help narrow down your problem.
From what you've posted so far it could be the input shaft bearing, a bad clutch disk, or contamination on the clutch (oil). All general guesses right now but I would see what other responses you get to you question.
