Porting intake pictures.
Old Apr 4, 2006 | 11:30 AM
Aardwolf's Avatar
Aardwolf
Default Porting intake pictures.
I've been working on my Big Mouth intake. Here's a picture cleaning up the casting ridges in the intake base. Once I was done I used steel wool to make it very smooth.
A picture polishing the plenum. I used a brass brush bit in my drill. I chose to make it more of a satin finish then smooth and mirror like. If you use the brush in a die grinder it will smooth the metal down quickly.
Next is a picture porting the plenum. I removed all the square metal walls. They were just inside the TB openings and between each pair of runner openings. Now if you look down through the plenum it is a straight shot for the air.
A picture while port matching the AS&M runners to the plenum. I shined a work light down the runner. It looks like afterburners!
I will post dyno and track results once I am finished! There are a few more pictures in the My Corvette photos link to the left of this text by my name.
Old Apr 4, 2006 | 11:42 AM
cv67's Avatar
cv67
St. Jude Donor '05
Kudos for trying it yourself, seeing more and more guys trying this
Heres one of a stock TPI base I recently did.
Old Apr 4, 2006 | 11:54 AM
cv67's Avatar
cv67
St. Jude Donor '05
THis guy does some beautiful home porting, cant wait to see how his base comes out.
http://forums.corvetteforum.com/show...ng&forum_id=48
Old Apr 4, 2006 | 12:34 PM
Aardwolf's Avatar
Aardwolf
What did you use to continue down through the base? Mine narrows and flows into a D shape. My bits have a tough time fitting in the corners in the middle. I thought of trying a smaller dia. sanding drum but it's also tough to get the angle so that the extension doesn't rub around the runner opening/gasket area. I didn't try to port or change the shape, just clean up the casting mess and then polish. It looked like if I wanted to port I'd have to pay close attention to the shape, how the air changes from the circle to D shape. To make the exit into the head smooth and not turn the air sharply.
Old Apr 4, 2006 | 03:08 PM
comp's Avatar
comp
Old May 18, 2006 | 08:46 PM
88BlackZ-51's Avatar
88BlackZ-51
let us know when u get those dyno #'s.
Old May 19, 2006 | 07:52 AM
fredk's Avatar
fredk
The import boys are cutting the top off the manifold, porting it and then welding it back together to get inside a lot easier. Just a thought.
Fred
Old May 19, 2006 | 08:03 AM
anesthes's Avatar
anesthes
Fred
To spend that much time on a LTR setup would be insanity.
-- Joe
Old May 19, 2006 | 08:17 AM
88BlackZ-51
Fred
i have a friend that did that with the tpi. he hasnt tested it yet.
To Porting intake pictures.
