drive shaft
Old Apr 4, 2006 | 02:53 PM
mudslide's Avatar
mudslide
Default drive shaft
Anyone ever pull a drive shaft on a 1990 L98 conv. without removeing the c-beam??
Old Apr 4, 2006 | 07:33 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It will come off. PULL PULL it will come off !!
Old Apr 4, 2006 | 11:30 PM
1987C4's Avatar
1987C4
Not on that year, but on my 1987 I just removed the rear C-beam bolts and one of the front ones while loosening the other front bolt and rotated the C-beam slightly to one side without totally removing it. It allowed me to get at the rear bolts easier and remove the drive shaft without any problem at all. I wonder if it would work on your year?
Old Apr 6, 2006 | 08:25 AM
mudslide's Avatar
mudslide
Well I finnaly got the drive shaft in with the c-beam installed but on a 1990 you have to bend a piece of a spot welded flange thats just above the shaft. It was so much easyer to get at the bolts on the beam without the shaft in the way.
To drive shaft
