#24svo injector fit ???
Old Aug 18, 2001 | 04:51 AM
88sk's Avatar
88sk
Default #24svo injector fit ???
replacing inject.,I noticed svo inj. are shorter than the stock ones, what can be done to make these a tighter fit(no leaks) on my 88, i read a post a while back about washers, any info would be apprec.&whats a good press.(adj. fuel reg.) to set them at, as we speak am install. accelbase, slp siamese runners, put hookers on also??? :confused:
Old Aug 18, 2001 | 09:15 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: #24svo injector fit ??? (88sk)
The difference is minimal and no correction should be needed. Just make sure all the O rings seal. Make your own AFPR.
Old Aug 18, 2001 | 10:32 AM
righton's Avatar
righton
Default Re: #24svo injector fit ??? (Aaron's 87)
I replaced my SVO with accel . My SVO had 4 small fuel holes in the base of the fuel injector.I had poor starting and rought idle. The diacom-p wot readingd were the same .Accel are made by bosh and are the same lenght as the SVO made by bosh
Old Aug 19, 2001 | 05:10 AM
88sk's Avatar
88sk
Default Re: #24svo injector fit ??? (righton)
has anyone else had hard start &idle problems with svo injectors?? :rolleyes:
Old Aug 19, 2001 | 11:20 AM
-=Jeff=-'s Avatar
-=Jeff=-
Nope I have had mine for just over a year on my current motor.. no problems yet
Old Aug 19, 2001 | 12:56 PM
MagRed_04's Avatar
MagRed_04
Default Re: #24svo injector fit ??? (-=Jeff=-)
No problem with mine... The car starts better than it did before!
Old Aug 20, 2001 | 03:09 AM
88sk's Avatar
88sk
Default Re: #24svo injector fit ??? (Vette_Crazy)
vette_crazy,any noticeable improv. with the slp runners, im finishin up accel base, svo inj.&slp runners, put hooker#2149 on 2wks. ago.. btw nice car.
To #24svo injector fit ???
