1995 driver side interior light switch...where?
Old Apr 10, 2006 | 05:29 PM
Phase 3's Avatar
Phase 3
Cruising
Default 1995 driver side interior light switch...where?
Hi,
Sometimes, when I open the drivers side door, the interior light does not turn on.
Does anyone know where the interior light switch is activated?
Thanks,
Elliot
Old Apr 10, 2006 | 09:15 PM
jfb's Avatar
jfb
I'm sure its in the same place as my 87. The door jamb switch is located in the door frame, on the forward vertical section of the frame, about level with the door hinge.
Old Apr 10, 2006 | 09:19 PM
VenkmanP's Avatar
VenkmanP
Rear edge of the door, below the latch.
Old Apr 11, 2006 | 12:03 PM
SJW's Avatar
SJW
Correct. I just replaced the one on my '94 a coupla weeks ago.
Be well,
SJW
Old Apr 23, 2006 | 09:53 PM
Phase 3's Avatar
Phase 3
Cruising
Thanks for the replies guys.
I think my problem is a relay. When the car is cold, and you open either door the interior light does not come on. After the car is started the interior light does come on when either door is opened.
I'm figuring that once the car is started, the charging system has a higher voltage than the battery alone. The battery is one year old.
Does anyone know where the relay for the interior is?
Thanks,
Elliot
To 1995 driver side interior light switch...where?
