Converting L-83 to LT4
Old Apr 11, 2006 | 10:48 PM
Monkeynutz's Avatar
Monkeynutz
Default Converting L-83 to LT4
Anyone done this?
Old Apr 11, 2006 | 11:03 PM
Fubar569's Avatar
Fubar569
you need
motor
trans
ecm
complete harness
lots of beer
some help
and much more im forgetting, but beer is most important!
Old Apr 11, 2006 | 11:10 PM
C-4 Now's Avatar
C-4 Now
either Vette or Corvette Fever covered this swap in middle to late 90's don't remember when? Maybe someone with organized collection can help?
Old Apr 11, 2006 | 11:23 PM
bogus's Avatar
bogus
fubar has pretty much summed it up.
Old Apr 11, 2006 | 11:51 PM
FD2BLK's Avatar
FD2BLK
I did the swap from a L83 in my 84. Do a search and I cover it prety well several times. First off you do not need a trany, I reused my 700R4 from my 84 and it worked fine. When i did the swap i used a F-body LT1, corvette LT1 assy bracket and A/C, the F-body P/S pump and alt. I did all the wiring my self splicing the LT1 harness into the 84 stock wiring to give it a stock look and feel. When I sold the motor I did change the harness to a stand alone unit.
Here is a short list:
1 Use your stock motor mounts
2. stock trany, if auto need a lock up kit and 92/93 TB or S&P adaptor
3. you will have to fab some fuel lines, (any local hose shop should be able to take care of you here)
4. Will need A/C lines fabed
5. need to find a place to run the steam vent (I taped the low coolant sensor on the 84)
6. Wiring, Jims Performance will do it for you, painless is another option or do what I did, by Charles Probst Corvette fule injection book and wire it your self.
7. ECM VATS disabled and what ever other changes you want.
8. Impalla SS throtle cable
Here is a shot of the compleated project.
Old Apr 16, 2006 | 11:54 AM
Monkeynutz's Avatar
Monkeynutz
What is a TB or S/P adapter and where would I find one?
Old Apr 16, 2006 | 12:06 PM
CFI-EFI's Avatar
CFI-EFI
Oh Yeah! Like THIS is gonna happen.
RACE ON!!!
Old Apr 16, 2006 | 12:57 PM
FD2BLK's Avatar
FD2BLK
TB is short for Throttle body and S&P is Street and Performance, they make swap kits for most moder Fuel Injected motors
Old Apr 17, 2006 | 12:38 AM
Monkeynutz's Avatar
Monkeynutz
Hush CFI! This is my first time putting an engine together! I'm slowly purchasing everything and my money is slowly disappearing.
Old Apr 17, 2006 | 12:58 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I would advice, if you are taking your time, waiting and putting in an LS1. No harsh feelings to my LT1 brothers, great motor, but the motor was limited production, with limited source of blocks and it also has the opti. If you are going to do something that requires this much work, you might as well swap in the newest block, LS1. JMHO.
Old Apr 17, 2006 | 09:09 AM
FD2BLK's Avatar
FD2BLK
I have no idea how much an LS1 conversion cost but I do know it is a lot more work. If I had to do it today I would probably go the LS1 rout if I had the funds. The LT1 swap cost me 3K including rebuilding the motor and made great power. There are a ton of LT1's out there dirt cheap at the moment. The upside of a LT1 swap is it bolts in with no mods to the motor mounts, exhaust, Frame, or trany.
Old Apr 17, 2006 | 05:40 PM
nelson84's Avatar
nelson84
How much did it cost to swap the lt4 in?
In corvette fever, I have the issue somewhere, It said it costed about 15,000 to do the complete swap. But they said some of your dash won't work, all that stuff in the information screen, oil temp,milage etc.
Old Apr 17, 2006 | 05:44 PM
nelson84's Avatar
nelson84
You should just buy a 96 lt4 for what it costs, and you will have the first and last c4, that would be sweet! You could grag race them and compare everything each has and I bet you will find something on the 84 better than the 96.
Old Apr 18, 2006 | 12:33 PM
Monkeynutz's Avatar
Monkeynutz
Can you put an LS1 into a c4?
Old Apr 18, 2006 | 12:38 PM
LT4POWR's Avatar
LT4POWR
I'd do a LS2, it's not even close, just my $.02
Old Apr 18, 2006 | 01:01 PM
FD2BLK's Avatar
FD2BLK
It was an LT1 but it was right at 3K. As far as the dash goes the only thing that did not work was the MPG. I don't read Corvette Fever and have no doubt they could some how tie up 15K in the swap and still not have the dash working correctly. The sensors the dash uses are a direct fit into the LT1 block, oil temp, Oil Presure, and coolant temp sensors, so if they could not figure that out then perhaps they should not have wrote the article.
Old Apr 18, 2006 | 01:12 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I'm afraid I would have to agree.
Larry
code5coupe
Old Apr 18, 2006 | 08:16 PM
nelson84's Avatar
nelson84
rocco16
We are the super friends! quote from the simpson.
First person on this forum to agree with me.:o
Old Apr 18, 2006 | 09:50 PM
Brinitvette's Avatar
Brinitvette
I'm in the process of a 84 L-83 (Crossfire) to LT1 swap.I'm pretty sure I'll have under 3k in it , and thats including the price of the car. Thats an estimate but, still i'm 80% of the way done.
To Converting L-83 to LT4
