Help needed thanks
Old Apr 12, 2006 | 04:15 AM
The Hobbit's Avatar
The Hobbit
Default Help needed thanks
Hi.
I just got my 80 k 86 vert back from the spay shop after 4 months ( I know, very long story) and apart from it looking great I seem to have developed a worrying problem.
before it went in the oil pressure was 70 cold and about 60 at 2000 rpm (200 f) and around 45 @ tick over, Its now 51 cold and varies from about 45 to 50 driving and 35 tick over hot.
I have not done any great mileage in it yet as I was trying to figure what is going on? When I first got the car, 4 years ago the oil pressure would be a bit erratic but after a couple of oil changes and rad cleans etc, it sorted itself out, I am not sure if what I am seeing is just an electrical gremlin or if its possible the pressure release valve in the pump is stuck open?
How hard is it to change the pump with the engine in the car ?
I will do an oils change and flush this week end and see what happens, but this is a bit of a kicking after being so pleased to get it back.
All ideas gratefully received.
PS I always use Mobile 1 0-40 and change it once a year - about 3 to 4 K
Old Apr 13, 2006 | 07:09 AM
The Hobbit's Avatar
The Hobbit
Originally Posted by The Hobbit
Hi.
appreciate any ideas
Old Apr 13, 2006 | 11:49 AM
CFI-EFI's Avatar
CFI-EFI
Hi.
You had your Corvette neutered???
Your oil pressure was WAAAAY too high, but it sounds like it is getting better. Maybe more surgery would help.
...or if its possible the pressure release valve in the pump is stuck open?
If the oil pressure RELIEF valve were stuck open, you would have zero oil pressure.
If you have any doubts or concerns over your oil pressure, the first step is to recheck it with a known good mechanical oil pressure gauge.
Changing to a more conventional 10W-30 oil may also help to drop the pressure into the "normal" range.
RACE ON!!!
Old Apr 13, 2006 | 02:15 PM
redrose's Avatar
redrose
oil pressure senders are themselves quite erratic....intending to use an oil press sender for another project,i set up a bench test to check accuracy--after trying four different manufacturers, i shelved the project due to inconsistent output of the senders...in other words,don't worry about it,as long as you have some pressure.
using 10w-40 motor oil (ask me how i know) will cause your engine to burn oil, as i remember the owners manual recommends 10w-30.
motor oil is hydroscopic and absorbs moisture from the air...unless you are in a very dry climate, oil should be changed every 6 months
Old Apr 13, 2006 | 02:18 PM
C4driver99's Avatar
C4driver99
neutered
Old Apr 13, 2006 | 04:42 PM
kize's Avatar
kize
It might be that your sending unit is going south. I would actually test your oil pressure before deciding to replace your oil pump.
Old Apr 18, 2006 | 10:31 AM
The Hobbit's Avatar
The Hobbit
RACE ON!!!
Thanks for this, I took the car out for about 50 miles this weekend and it seems more constant now so its probably the sender. What would you consider to be normal oil pressure in a sbc, I know that the min is normally quoted as 10 psi / 1000 rpm .
I spoke to a mobile oil technician before switching to 0-40 and he's advise was that the 40 would be fine in this age of engine, and as you can only get 0-40 or 15-50 in the uk I went with that, note: M1 is about 48 pound for 5 lts i.e. nearly $90 a fill, so I looked into it quite carefully before changing.
Old Apr 18, 2006 | 11:54 AM
CFI-EFI's Avatar
CFI-EFI
The pressures you report seem to be on the high end of normal. They don't appear to be anything to worry about, as long as you can confirm their validity with a known good, mechanical gauge. Your opening post made it sound as though you were concerns with the excessively low oil pressure you observed after getting your car back. *I* was concerned with the numbers BEFORE the work.
RACE ON!!!
Old Apr 18, 2006 | 01:18 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Bazza,
How you been. Moved back up North now. If you need a new sender to test, I've got a couple in stock.
You going to the Nats this year? At Huntingdon Racecourse now.
Old Apr 19, 2006 | 04:06 AM
The Hobbit's Avatar
The Hobbit
Originally Posted by Ray Quayle
Bazza,
I noticed it had moved, good for me its a lot closer so I will definatly be there. Any idea why it moved?
If its not a problem I will take you up on your offer, what pressure does your 86 run?
Hope all is well
Barry
Old Apr 19, 2006 | 11:56 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
I think the CCCUK just got a much better deal at Huntingdon. Their share of the gate is much higher, and you can camp on site. The Novatel had seen better days and there were many complaints about the food. The Marriott should be much better. Time will tell. Also better for me, with Alconbury being right there, I have some facilities handy.
I run no lower than 30 psi at idle at 225°F and it has been thaqt way since I picked it up in December '86. email me your snailmail address and I'll post you the sender. Unless you want to wait until the Nats.
To Help needed thanks
