What the hell is code C12 on module one?
Old Apr 12, 2006 | 04:59 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default What the hell is code C12 on module one?
This is the CCM, correct? Well the manual starts at DTC13.... WTF is up wid dat? Oh, it's on my '95 LT1. I have no CCM issues that I know of.
Old Apr 12, 2006 | 05:49 PM
Steel Blue 91's Avatar
Steel Blue 91
I think you are still running OBDI. If so it's like my L98 and C12 is just a check value. Not too familar with the 95 LT1 so I might be mistaken.
Old Apr 12, 2006 | 08:20 PM
Corvette Kid
Yes, last year of OBD I with a few OBD II characteristics thrown in just to make it interesting!
Old Apr 12, 2006 | 08:21 PM
Red Dwarf's Avatar
Red Dwarf
C 12 indicates that the diagnostic system is operating & that you have no stored DTC'S in the CCM.
You are OBD I with some OBD II codes that were inserted prior to mandatory compliance to II in 96
for testing purposes.
Old Apr 12, 2006 | 08:23 PM
aminnich's Avatar
aminnich
That's the best code and only one you ever want to see. Relax, have another brew.
Old Apr 12, 2006 | 09:06 PM
Corvette Kid
Thanks fellas, I believe I will!
Old Apr 13, 2006 | 09:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
A blank DIC screen is a good DIC screen.
Old Aug 8, 2022 | 10:44 AM
Steves1991C4's Avatar
Steves1991C4
I was reading your reply sounds like you are familiar with the Codes for my 1991 C4 I am having trouble understanding the display. I jotted down a few of the numbers: I hope you can help me understand this please.
Module 1.2
01=174
02=0
03=16
04=599 or 533 hard to tell a 9 from a 3
05=0
06=35 or 95
07=122
08=11.6
09=85
10=71
11=100
12=100
13=148
last parameter had no number assigned -- 3 180 123
Old Aug 8, 2022 | 11:40 AM
Steves1991C4
sorry I am not sure what VATS is exactly -- but I couild not make out the difference between a 3 and a 9 on the digital read out. So it is one of the two. I have to get a younger person to read the screen. I assume 06 is a 35. Do you know what or where to find the a description of the numbers I am seeing?
Steves1991C4
I have the FSM just cant understand what a 174 code is. I have been searching the code discriptions in the FSM.
Old Aug 8, 2022 | 11:41 AM
Steves1991C4
Also what component on my car relates to Module 1.2 parameter 06 for instance.
Old Aug 8, 2022 | 12:43 PM
Steves1991C4
thank you so much for the info. Going to those pages now in my FSM. Thanks again. I have been having AC control head issues. AC is fine but it is not controlling when I reset the codes it works using 1.7 and 4.7 weird. I also know I do not have a reference to ground negative battery terminal to the engine so I am going to check my grounding points.
To What the hell is code C12 on module one?
