Carpet Install Tips
Old Apr 12, 2006 | 11:36 PM
jimmers's Avatar
jimmers
Default Carpet Install Tips
Just wondering if anyone has any tips on installing new carpet.
Old Apr 13, 2006 | 01:59 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Just finished my new mass back carpet intall this weekend, and now putting back together.
1. Save the carpet to use for templates on new
2. take alot of pictures
3. Me-after carpet removal I - cleaned/sealed & painted
4. While you're there, install sound & heat proof
5. Run any and all new wires for amps/speakers, etc
6. GET MASS BACK CARPET ONLY
7. Make sure you warm it up in the house for 4-5 days before install
8. Heat or hairdryer gun to warm up the BACK only during install
9. Get good glue and make sure you wait the time to make sure its good and sticky
10. Install in specific order 1. Back wheel wells, 2. behind seats, 3. trunk & storage pieces, 4. DS & PS floor, 5. Trans tunnel sides
11. Don't over trim new pieces
12. Remove and label all parts & screws by section
Have fun
Old Apr 13, 2006 | 04:56 AM
comp's Avatar
comp
insulate while your at it
Old Apr 13, 2006 | 07:45 AM
1stC3Vette's Avatar
1stC3Vette
Have fun
Excellent advice. I did the same. The only difference was that I bought an interior screw kit just to replace them with new. The sound proofing helps out tremendously.
Good luck,
Dino
Old Apr 13, 2006 | 09:38 AM
jimmers's Avatar
jimmers
Thanks for the tips! I did do the sound/heat material and i'm at the point to put the carpet in. So does the hair dryer heat it up enough to mold it better to the car?
Old Apr 13, 2006 | 02:10 PM
C4driver99's Avatar
C4driver99
Yes the heat makes the backing of the carpet more pliable therefore more advantage to you making it a less tedious job
Old Apr 13, 2006 | 04:37 PM
vinnies87's Avatar
vinnies87
Yes, definate a positive, i used a Heat Gun, more heat, more power... just be careful to do the back of the carpet only and move evenly around, i did use a hair dryer on the carpet side after carpet in place to do the final molding and help dry the spray faster... just be carfull.
I also got a new screw set as well as a bunch of new replacement parts and did some in leather to help accent the interior. I'll post pics later when more complete, before seat installs.
To Carpet Install Tips
