IAT sensor housing for ATI Kit
Old Apr 13, 2006 | 01:27 AM
lcvette's Avatar
lcvette
Default IAT sensor housing for ATI Kit
I was wondering if anyone knew if the reinsertable sensor plug on the procharger kit is available for another car from the factory? I am trying to find a good spot for the sensor and would like to weld on a bung like ATI does in their kit. any help appreciated!
Chris
Old Apr 14, 2006 | 08:36 PM
Mo_Bandy's Avatar
Mo_Bandy
Hey Chris,
The threads are differnt than the Vortech system..
If you use like water / meth injection you run the risk of shorting out the IAT...
I ran mine and mounted it to the blower fan at the the rear of the engine compartment so it is just "pulling" the ambient air in the engine compartment.
You could probably mount it right behind the airfilter as well if you still want it in the inlet path...
Hope that helps!
Mo
