Has anyone installed an electric water pump in a remote location? I'm considering one behind the motor on the frame rail. Any pictures of your installation?
Also is there a flow path diagram of the coolant flow through an L98 motor somewhere on the internet?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I haven't heard of anyone running a set-up like this. Regarding coolant flow, all you really need to know is that the bottom radiator hose is the coolant return path from the radiator. I think you can figure it from there. Sounds interesting. What kind of pump are you considering and what's the reason for the remote set-up?
I like this idea for maintenance reasons - for example the M3 I used to have had a remote canister for the oil filter, made changing the filter a snap and no mess.
