Horn issue
Old Apr 13, 2006 | 02:02 PM
AJ90's Avatar
AJ90
6th Gear
Default Horn issue
Hello,
I just purchased a 1990 convertible. It is very clean and in stock condition.
I noticed that the horns were not working. They are both disconnected at the horn, when I plugged them in, they blew constantly.
The steering column does have a very small amount of up and down "play" in it--maybe 1/8".
Does anyone have any suggestions as to where to begin to solve this problem??
Thank you very much.
Old Apr 13, 2006 | 02:16 PM
C4driver99's Avatar
C4driver99
Start with the electrical wires in the hood located near the front see if theres any shortages, cut wires ect. I doubt the play in your wheel causes this. If your a home mechanic and got a diagnostics available you can probably solve this quickly and cheaply. Id say if you wanna be lazy buy all new parts and spend the extra $$ GOODLUCK Hope someone wiht more experience chimes in
bogus's Avatar
bogus
I would bet the horn relay is fried.
or the horn wires inside the wheel are sick.
either way, you are a new owner, so order up a copy of the Helm Factory Service Manual, www.helminc.com. You might find a used copy at ebay or here in the parts for sale section.
C4driver99's Avatar
C4driver99
BTW also might be a bad relay switch. Affected all electronics in my car
To Horn issue
