Window Trim
Old Apr 14, 2006 | 07:25 AM
Larry64's Avatar
Larry64
Default Window Trim
How hard is it to replace the weather strip on the bottom inside and outside of the doors. Mine are hard and cracked and need to be replaced.
Old Apr 14, 2006 | 10:51 AM
C4driver99's Avatar
C4driver99
not to bad.....if u got the right tools
Old Apr 14, 2006 | 11:16 AM
87vette's Avatar
87vette
I just did my outside strips... you need to pull off the door panels. For the outer strips.. you need a slotted screwdriver to pull off the 3 rivets and hammer down on it till it breaks off. There may be some parts of it stuck in the holes where you will need to drill it out. Just be careful not to drill too far or you will put a hole in the door. Other than that just snap the new ones in place. As for the inner strip.. it is attached to the door panel itself. Mine were stapled on and I couldnt get a staple gun to puncture through it so I went ahead and use some strong glue to hold it in place. We will see how it goes once I get everything back together again.
Old Apr 14, 2006 | 11:19 AM
C4CBF's Avatar
C4CBF
how much does it ususally cost for a set of weatherstripping? Where is a good place to find it? Thx
Old Apr 14, 2006 | 11:43 AM
87~C4~Driver's Avatar
87~C4~Driver
WWW.ECKLERS.COM thats all im going to say
Old Apr 14, 2006 | 12:02 PM
87vette's Avatar
87vette
I bought a full set for both windows inner/outer from a guy off ebay for $84 dollars. This price beats all others out there. They are stiff right now but it will take a bit for it to form to the windows. I'm pleased with them however. The sellers name on ebay is.. " theweatherstrip store" Here is a link...
http://stores.ebay.com/THE-WEATHERSTRIP-STORE
To Window Trim
