Engine bearing swap.
Old Apr 14, 2006 | 12:15 PM
devilfish's Avatar
devilfish
Default Engine bearing swap.
If you going to do a bearing change ( main and rod ). Is it enough to "just" look at the inprint on the orginial bearing and replace it with the same new part, and then torque it down? Do I need new main bolts or can i re-use the old ones.
( no its not my engine, its a older truck engine that needs a bearing change )
Thanks.
Old Apr 14, 2006 | 01:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just reuse the old ones and make sure the threads are clean before torquing.
Old Apr 14, 2006 | 01:50 PM
rick lambert's Avatar
rick lambert
I've done it-as long as the old bearings weren't trashed, and yes you
can re-use the main bolts.
To Engine bearing swap.
