Front spring removal and installation tool
Old Apr 14, 2006 | 02:12 PM
helopilot's Avatar
helopilot
Default Front spring removal and installation tool
Does anyone know if the GM service tool for removing and installing the front spring is available for purchase anywhere or if anyone makes a similar tool for this application. I need to change out my front spring due to delamination and after reading the tech tip I'm not sure I'm comfortable doing this with a floor jack. I've done coil spring replacements before but only with a proper spring compressor.
I'm no supermodel but I'd rather not have my face and appendages "modified" just to save a few bucks in the long run. The local GM wants $225 for the labor to do this and I'm thinking it may be worth it. I thought if such a tool was available it probably would've been posted somewhere already, but just thought I'd ask anyway. Thanks!
Old Apr 14, 2006 | 02:48 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Using a floor jack for this job?
Jack the car up and put it on jack stands.
Use two small bottle jacks to hold the tension on the old spring at each end. When you detach it , slowly unscrew the air valve in the bottle jack to allow the tension to come out of the spring safely.
If you don't already have these....then spending the $225 at the shop is probably a good idea for safety
Old Apr 14, 2006 | 03:30 PM
WVZR-1's Avatar
WVZR-1
Default Might be a deal!
If the labor you were quoted included the "required" alignment, the $225 sounds like a bargain. Do you know these guys? If they've got a quality suspension and alignment guy that's familiar with the operation it might be the way to go. I'd try to speak with the tech maybe first and make the call after your conversation.
Alignment probably isn't included but I'm surprised they would quote the job without it!
Old Apr 14, 2006 | 04:00 PM
96GS#007's Avatar
96GS#007
A floor jack will work fine. Put a square piece of wood on the jack saddle to keep from maring the aluminum lower control arm surface. The jack will never actually be in contact with the spring.
The end of the front spring sits on/"in" the lower control arm. The middle of the spring is bolted to the front crossmember and isn't going anywhere even if the jack were to move. Just be sure to have the jack under/supporting the control arm before popping loose the lower ball joint. When you do pop the ball joint loose, lower slowly until the tension is released.
Old Apr 14, 2006 | 04:06 PM
aboatguy's Avatar
aboatguy
I use the floor jack inline with the spring so the there is no chance of the jack tipping over and becoming a projectile.
Mike
To Front spring removal and installation tool
