seeking help with problem diagnosis.
Old Apr 16, 2006 | 02:00 PM
Morley's Avatar
Morley
Originally Posted by rick lambert
what happens if the IAC is so carboned up-or simply fails so that it can't open? I don't mind being taught, what I do mind is sarcasm in the teaching-which is simply uncalled for! reminds me of the days they used to slap your hands with a ruler if you missed a key in piano class.
A very dirty IAC can cause a "wandering" idle, ie theIAC is commanded to open and give more air for a faster idle but is gummed up and moves slowly. The ECM seeing no real increase from its commands will then command it to open further...the IAC will eventually overshoot the target idle and the ECM will command it closed...same thing happens on the way closed. The idle will have a lazy "wandering" quality rather than a real hunting idle.
Now, if it gets stuck closed the car may not stay running when cold started (yo need a little higher idle on a cold start to stay running) or the car may stall when stopped and the A/C comes on or the fan kicks on because the idle adders tha ECM commands never happen and the engine gets loaded down.
Old Apr 16, 2006 | 03:15 PM
illinest's Avatar
illinest
yay morley! that actually sounds kinda like what I have.
@ rick and cfi - please don't get my thread closed down. I am learning from your debate but it looks like it's turning a little too personal.
@cfi in particular. I appreciate that you're trying to help me. If not the IAC then what direction do you believe would be better to go in?
Old Apr 16, 2006 | 04:27 PM
rick lambert's Avatar
rick lambert
Cleaning the IAC is a great place for you to start, it requires very little effort, some carb cleaner and a tooth brush. When you pull it,just clean off as much carbon as you possibly can-hit the inside passages with a little cleaner too. Lube the O ring with some silicon or something similar.Re-install the IAC, it will have to be reset-we can help you with that too. Good Luck
Old Apr 17, 2006 | 03:47 AM
Mo_Bandy's Avatar
Mo_Bandy
As I tried to mention before ....
I had the same symptoms as you were discussing I found that the IAC was stuck , and it would not start cold... and when the A/C was turned on it would try to stall. Having to keep your foot on the throttle until the car suffieciently warmed up... as Morley also mentioned
I hope this gets you going...
Mo
Old Apr 17, 2006 | 06:52 AM
k99ja04's Avatar
k99ja04
Just my .02
I had a leaking injector in my LT1 that caused an excessive rich and made popping exhaust like you describe. Idle was poor as well. I did the standard clean throttle blades and IAC passages as well that didn't seem to really help. I also had leaking valve seals that explained my smokiness. I eventually nailed down the leaking injector when I hooked up a scan tool and saw really split BLM's. You need a leakdown test as opposed to compression test to determine if your valve seals are leaking.
There's another recent thread about some cleaner called Seafoam. I have no experience with it but others claim it helped their idle. Your problem is gonna be tough without being able to pull that intermittent code, then again not all problems post codes. But since you're getting a SES light that's the best place to start.
Old Apr 17, 2006 | 04:30 PM
CFI-EFI's Avatar
CFI-EFI
He used a simple analogy-look up the word!
I am familiar with the word. The choke serves richen the fuel mixture on a (usually cold) carbureted engine. An IAC has no analogous function. The IAC simply regulates the idle speed at the command of the ECM, and has NO effect on the A/F ratio. It is nice if you know the meaning of the word "analogy", but for the purposes of this thread it would be better if you were familiar with the workings of a choke and of an IAC,
while you're at it-remember one of my very first posts "the main fan is controlled by the ECM" , twice-not once-but twice you-in your hollier than thou attitude admonished me-said I was wrong!-only to eventually come back and say-"I admitt I didn't check the entire wiring diagram" did I admonish you? NO! learn how to communicate with others and Get a life!
Certainly I make mistakes. I have no recollection of what you have put in quotation marks as me having posted. You MIGHT be referring to a typo, because it has been burned into my brain for quite some time that the main fans on ALL C4s are controlled by the ECM, except for the 1984. And if I spelled "admitt" with two "Ts" as you have quoted me, it surely was a typo.
RACE ON!!!
Old Apr 17, 2006 | 04:38 PM
CFI-EFI's Avatar
CFI-EFI
I am not saying that the problem isn't or can't be the IAC. In fact I think it is quite likely that the IAC is the cause. I merely corrected the comment that the IAC acted like a choke and that the IAC could change the A/F mixture, which is the purpose of a choke. It can't.
RACE ON!!!
Old Apr 17, 2006 | 10:40 PM
illinest's Avatar
illinest
to be perfectly fair, I didn't know what a choke is. I have no understanding of carburation so I figure the point is moot.
So thanks Mo... I wasn't tricked by an improper analogy cause I couldn't key in on improper usage of a car term. No problems.
IAC won't get checked until this weekend at earliest. I'll definately revive the thread when I have more news.
Leaky injector btw.... that's something that I haven't ever thought of. Is that common on these cars? Bad?
Old Apr 18, 2006 | 12:32 PM
rick lambert
Well, it sounds like we're all in agreement that the IAC is the most likely culprit.
illinest, to answer your last question about injectors, whether on vettes or anyother car,they can leak, simply because of age, or infact some new injectors may also leak. Because the majority of discussion here is about vettes we hear alot about leaky injectors-or suspected leaky injectors. It's very easy to check, you simply need a fuel pressure guage. You connect the pressure guage to the schrader valve on the fuel rail,turn the key to the on position and (if the relay is working properly) watch the system pressurize-it should reach somewhere in the 40 range-then you shut the key off and watch the pressure guage-if it drops rapidly, that is a sign pointing to a leaky injector(s). Good luck with the IAC-and let us know.
