well if it leaks enough and you run out of fluid BYE BYE BRAKIES On the other hand if you keep as is its gunna be a pita because your gunna be coughing up 6 bucks every week for fluid
There is only one thing more important than going fast... STOPPING. Don't screw around with your brakes. I just finished doing new rotors, pads, master cylinder, and braided brake hoses. Make sure when you replace the parts, that you flush all of the old fluid out until you have clean fluid.
Seriously, the front brakes probably account for about 75% of your stopping power. If you mess around with that by letting the master cylinder go dry, you lose the brakes. Fix that immediately.
