Tranny has screwed me over
Old Apr 14, 2006 | 06:24 PM
C4driver99's Avatar
C4driver99
Default Tranny has screwed me over
My transmission is F***** up its leaking fluid whenever i drive it and makes smoke cause its flying against the hot exaust piping and idk whats wrong it shifts great, no slippage???? Is it possibly a bad gasket or is my tranny shot PLEASE HELP!!!
Old Apr 14, 2006 | 06:25 PM
C4driver99's Avatar
C4driver99
Also I have no records of any tranny trouble prior to this
bogus's Avatar
bogus
yes. you have a leak. get under the car and isolate where it is coming from. my guess, the output shaft seal.
Old Apr 14, 2006 | 06:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cheap part, not difficult to change.
Old Apr 14, 2006 | 07:06 PM
C4driver99's Avatar
C4driver99
thanks ill check it and keep you posted
Old Apr 14, 2006 | 07:20 PM
Pete K's Avatar
Pete K
Don't panic yet. If it is an external seal, replacing it is the obvious answer. If it is over filled, it could be puking out of the vent at the top. If fluid level is correct and it is puking out the top, then worry.
Old Apr 14, 2006 | 07:37 PM
C4driver99's Avatar
C4driver99
Ok the level is good and no its leaking from the bottom but i cant see where yet
Old Apr 14, 2006 | 07:43 PM
Pete K's Avatar
Pete K
The seal that usually erupts with no warning is often the front pump seal. Remove the 4 10mm bolts that hold the flexplate cover on and remove it. If it is fill with some fluid, it is likely a front seal. The 86 and earlier units had a problem with fluid pressure pushing out the front pump bushing. If this has happened(and I doubt it) There is a mod you can make to prevent it from happening again.
Old Apr 14, 2006 | 10:49 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
all good advice. just keep the fluid topped off between now and the fix. i have a great book that says a car never knows it has a leak--it only knows when it is low on fluid. if the leak is the only symptom, then you're probably lucky.
i just have to remark on the differences between your first and second post--frantic to calm. take a look.
we've all been there.
i hope you find an easy problem and at least have a laugh later.
Old Apr 16, 2006 | 08:47 AM
bacardioil's Avatar
bacardioil
pete k
is more then likely on the money with your problem.
Old Apr 16, 2006 | 10:20 AM
sami85L98's Avatar
sami85L98
Originally Posted by bacardioil
pete k
I may be mistaken or did not understand this statement, pete never tells anyone on CF to rebuilt from him, he always sticks to his words to fix/rebuilt at ur local place and instead he gives free tech advices here, dont take me wrong pete. k is a wonderful man with good attitude and never expect to get anything from u. period.
Old Apr 16, 2006 | 10:34 AM
Pete K's Avatar
Pete K
This is true. I do not push myself on anyone on the forum. Always happy to help if I can. I make it a point to let everyone know that I am in the construction business by day. Trans is hobby. I get a sick kick out of being able to do the really difficult stuff.
Buying a trans off the internet can be a bad experience sometimes. Very expensive to r&r and ship back for repair. I always suggest a local pro if possible. Problems are dealt with much better.
The last 2 builds went to europe. 1 to stingraymarc in germany and the other to Nico. I am quite eager to hear how everything went for both. A bit nerve wracking though. It is hard to help someone on the other side of the planet if , god forbid, they have a problem.
Old Apr 16, 2006 | 10:46 AM
bacardioil's Avatar
bacardioil
pete
all will be fine, have faith.
Old Apr 16, 2006 | 10:49 AM
Pete K's Avatar
Pete K
pete
Thanks Gene. I did the best I could do and the plane delivering them did not crash! Confidence and faith I have. Bad luck is what concerns me (in the back of my mind)
Old Apr 16, 2006 | 12:28 PM
rick lambert's Avatar
rick lambert
We've never had any dealings Pete-but like most on this forum-I certainly respect your post.
Old Apr 16, 2006 | 01:54 PM
C4driver99's Avatar
C4driver99
nah you seem talented at what you do
To Tranny has screwed me over
