Lt1 intake conversion 98% done: little problem
Old Apr 14, 2006 | 08:41 PM
dirtnapp's Avatar
dirtnapp
Default Lt1 intake conversion 98% done: little problem
Just started my car up with my LT1 intake on it. It sounds great off idle but I am having some trouble getting a good idle. I played with the timing alot and adjusted the fuel pressure to just about every pound from 30-50 psi. It stumbles, pops and sounds like it has ahuge cam. The only thing I can think of is the injectors. I put 24# injectors in. I do not have a chip for it either. Should I put the stock 22# injectors in? Will it help or hurt?
Old Apr 14, 2006 | 08:46 PM
86Pacecar's Avatar
86Pacecar
Check your plug firing order. Very easy to mix up 5 and 7. My 86 did this when I had the 5 and 7 wires swapped. Just looked again and saw that yours is an LT1 not sure if firing order is the same.
Old Apr 14, 2006 | 08:50 PM
dirtnapp's Avatar
dirtnapp
Mine is the same firing order. It is an L98 with Lt1 intake on it. Just checked it...they are correct. Thanks though
Old Apr 14, 2006 | 09:54 PM
redrose's Avatar
redrose
my lt1intake/l98 runs super with the 24 lb injectors
Old Apr 14, 2006 | 09:59 PM
dirtnapp's Avatar
dirtnapp
do you have a custom prom? That may be my problem
Old Apr 14, 2006 | 10:19 PM
redrose's Avatar
redrose
no custom prom...ran good with stock prom, got a hyperjunk in now for fan temp....sounds like a vac leak or ignition prob, just w.a g.
Old Apr 15, 2006 | 01:36 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Are you still using the stock hook ups for the distributor ?
Did you disconect the est.I would set the timing at 6 or 8 degrees and lower the fuel presure to 39 lbs that should decrease the width on the injectors .Did you install a new 02 sensor?
You need to run the engine long enough to get the engine into closed loop atleast 180 degrees.
Old Apr 15, 2006 | 10:16 AM
redrose's Avatar
redrose
you said it sounds great off idle--is that under load while driving or just in the driveway?.....if revving in the driveway sounds ok but idle and loaded causes popping, i've seen that several times--too ez to be true--just bad spark plugs....no idea why but sitting for a while unused they go bad
Old Apr 15, 2006 | 10:35 AM
comp's Avatar
comp
got any pic's to add ???
Old Apr 15, 2006 | 11:39 AM
boisedarc's Avatar
boisedarc
8th Gear
Could very well be an intake leak, probably somewhere around the back of the intake. You might try using a vacuum gage to see where you stand, then use some carb cleaner and spray around the edges of the intake to see if you have a leak.
Old Apr 17, 2006 | 09:23 AM
dirtnapp's Avatar
dirtnapp
You were correct about the intake leak I found it last night. It is in the back of the intake. Hopefully all I have to do is take the distributor out to get to it. I will post some pics as soon as I load the progam on the computer for the camera. Just got another camera. I drove it last night. HUGE difference!! well worth the headache of fabricating it. The power is nice and smooth and I honestly don't notice the torque loss. It pulls hard past 5k with ease. Much better than TPI
Old Apr 17, 2006 | 09:27 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Its normal for LT1 intake cars to have a pop like they don't have enough accelerator pump until you get the car tuned..
Other than that it should run pretty ok.
Old Apr 17, 2006 | 10:46 AM
dirtnapp's Avatar
dirtnapp
I still have a few issues with it. It seems to be overheating and the throttle is very touchy. I also have low coolant light on and it is definitely full. The other issue is just minor tuning and like you said, a custom prom will take care of that.
To Lt1 intake conversion 98% done: little problem
