Just hook both fans (pusher and puller) up to one 30Amp relay. The relay will likely have a second "power" line if made specifically for automotive fan use (like the kinds you get in the parts stores), but if not then no biggie. Wire both fans in parallel off the 30 amp relayed circuit and then they'll both come on /turn off at the temps you mentioned. Just be sure to use good solid wiring (multistranded with thick insulation) and go a size over what you think you need for the current. For 30 amps, a 14 guage would be overkill but that's what I tend to use. You can keep the relay close to the radiator (for the thermometer function) and just run one single wire to the battery, then ground on the chassis by the radiator. Keeps the wiring clean. You wouldn't NEED to use the painless relay kit with thermostat, but it makes it easier than using a cylinderhead temperature sensor.
I know on my 87 I wired it so both fans come on together at 200, and off at 185-incidentally the main fan on at least the 87 was operated by the ECM, but it's easy to bypass this-but I thought on a 93 you had to have the computer reprogammed-new chip or whatever?
Do I need two kits to keep the fans at different temps, or can I just wire them together so they both turn on at the same temp?
YES!
Yes, you will need two kits (or other means of activation) if you want them to come on at different temps. Yes, you can just wire them together if you want then to both turn on at the same time (bad idea).
Originally Posted by ScaryFast
Also, will one relay be high enough current capability to handle two, or should I add a second 30A fuse and relay?
If your car came with two fans, it also came with two fan relays. Allow each relay to provide the power to run it's fan and use whatever else you prefer, to activate the relays, separately or together, which ever you decide.
YES!
RACE ON!!!
CFI - why do you suggest that it is a bad idea to turn them on at the same time? Too much cooling?
The car is a road race car only. I didn't provide much info in the original post but for clarification it becomes relevant.
I can easily stage the two kits and have a 185 and a 200 turn on temp, but is that more necessary for a street application, or is there a compelling reason to keep them separate in a track car?
i went with the painless setup but i didnt change my 160 stat. you get the relay, temp switch, fuse block and wiring. real simple deal for 50 bucks. thats for one fan i guess you could run two fans off one relay but they would come on at the same time. as far as the two fans coming on at diffrent times seems you would need two different rated temp switches????
Too much cooling, at least initially. Unnecessary wear and tear on the fan motors and an unnecessary draw of power from the alternator and consequently. the engine. Also, a running fan can impede the air flow trying to pass through the radiator, at speed.
those temps are WAAAY too cool for a street car. I have a single fan that comes on at 205°, but rarely does. When it does come on, sitting still, I can watch the temp drop until the fan shuts off at 195°.
Not sure if I would lose as much sleep as CFI does on the difference between 185* and 205*. Having the fans come on at a lower temp will result in them running longer than stock, but when the OEM fan lasts 20 years... not sure I'd be TOO worried about fan wear. Secondly, amperage draw is a consideration, but again not sure it's REALLY that big of a deal.
IMHO, this boils down to preference. If you're retentive and want the car to run that extra 5-15 temps cooler then you accept the tradeoffs of maybe buying one extra fan before the car falls apart; and of course a little less gas mileage from all that added engine load at idle (surely it will add up). Conversely, if you're retentive and want to avoid those little caveats, then keep the bastich stock and run those 230 degree temps for better emissions.
My fans hardly ever come on-never when cruising or in winter months.
They both come at the same time only when I get in traffic jams-or sitting for a long time ideling in hot weather.I can almost see the 180 thermostat opening, my temps get up to 185 in city driving, then cool to about 175-178-the temps stay in that range-unless the afore mentioned. My aux. fan is original-87, I did replace my main fan, but that was prior to changing the system, that was about 3 years ago, I did blow a fusible link, not long ago to the main fan relay-but the aux. still came on. I'm happy with my setup.BTW, mine are setup to come on at 200, and shut off at 185.
