Removing steering lock on my 87
Old Apr 16, 2006 | 08:40 PM
Don in Vermont's Avatar
Don in Vermont
Default Removing steering lock on my 87
Hi All,
Just wondering if anyone has removed the steering lock from their earlier C4. I have to replace the lock set and would like to remove the wheel locking mechanism at that time. Any comments or direction would be appreciated.
Regards,
Don
Old Apr 16, 2006 | 09:37 PM
MrRenoman's Avatar
MrRenoman
Are you asking how to disable the steering wheel lock mechanism while you are replacing the key cylinder? You don't want your steering wheel to lock when you remove the key?
Art
Old Apr 17, 2006 | 12:25 AM
bogus's Avatar
bogus
That's an odd request... just remove the lock ring plate.
Old Apr 17, 2006 | 06:34 AM
rodj's Avatar
rodj
Bad move.
If the early are the same as the '90 ,the lock plate (held on the column with a C clip) is what preloads the guts of the tilt mechanism.Take that out and the tilt falls apart.
Only way to remove pin is to dismantle top of column , so as to access the pin operated by the gear on the end of the key barrel , LH side.
Old Apr 17, 2006 | 02:12 PM
Don in Vermont
Default Steering wheel lock removal
Hi Folks,
Thanks for the replys. I am repacing the lock cyl. and I will take a look at the whole thing at that time. The reason I was asking is that the car is almost 20 years old and from time to time the link between the st wheel lock and the trany shifter is getting flakey. I realize the GM tried to do the thinking for us by designing the lock in the first place. I, for one, do not need the feature but I will probably just change the lock and forget about the wheel lock.
Thanks again
Don
Old Apr 17, 2006 | 02:46 PM
C4driver99's Avatar
C4driver99
BAD IDEA
To Removing steering lock on my 87
