Weatherstrip Question
Old Apr 17, 2006 | 01:57 PM
Biker's Avatar
Biker
Default Weatherstrip Question
I want to replace the door panel outer window seals on my '86 convertible. The replacement parts I saw on Ecklers state rivets are included. Are the original window seals riveted in place? Any tips or advice on changing the seals?
Old Apr 17, 2006 | 02:09 PM
RRT vette's Avatar
RRT vette
Yes, they have rivets I believe 3. The outer window weatherspripping has clips as well that slide down into holes on the inside door. You have to remove the door panels and let the window down to get access to remove and install. You will need a rivet gun to install rivets and the longest part is taking the door panels off.
