LT4 Gaskets?
Old Apr 17, 2006 | 02:10 PM
Achilleus07's Avatar
Achilleus07
Default LT4 Gaskets?
I'm doing my cam this next weekend. Since im putting on tons of stuff....spark plug wires, spark plugs, fuel filter, water pump, heavy duty timing chain, headers, power steering pump, and a few more goodies...I wanted to buy a full engine gasket set for the LT4 just to have them....since I will use a few of the gaskets anyways. Does any place sell a full kit? I would love Fel-Pro but thats looking out of the picture except for header gaskets. Any thoughts or any fingers that can point me in the right direction?
Old Apr 18, 2006 | 07:06 AM
Achilleus07
ttt
Old Apr 18, 2006 | 09:22 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I'm not sure if you can buy a full gasket kit to cover everything.
I just ordered all my gaskets with Chris at Superior Chevy. Each part I was replacing he knew what gasket I would need.
Be sure you use a bunch of Red RTV with your gaskets.
Old Apr 18, 2006 | 10:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I would get as many Fel-Pro gaskets as I could, then make up the difference with Chris at Superior Chevy.
Old Apr 18, 2006 | 01:25 PM
Mo_Bandy's Avatar
Mo_Bandy
You might check with Summit Racing, many times they don't list everything.... Yes as menioned make sure you get RTV for the intake.
When I put my long block together they had all the parts i needed...
MO
Old Apr 18, 2006 | 01:49 PM
Achilleus07
Awesome...thanks guys
Old Apr 18, 2006 | 04:20 PM
Zix's Avatar
Zix
I used Fel-Pro for my head and header gaskets, I used GM for everything else, and make use to get the 7777 intake gaskets rather then the stock ones, they line up the way they should!
Old Apr 18, 2006 | 09:26 PM
1996man's Avatar
1996man
does anyone other than GM make the 7777 intake gaskets?
Old Apr 18, 2006 | 09:41 PM
~db~'s Avatar
~db~
Get them from Chris at superior (777s as well). No need to look elsewhere unless you want aftermarket. He is good people!! I just got done doing what you plan on doin...have fun!!
Old Apr 19, 2006 | 12:01 AM
Zix's Avatar
Zix
I've never seen any other options for the 7777 gaskets, but then again I have honestly never looked. The GM gaskets are very good so I never looked for a 3rd party source.
Old Apr 19, 2006 | 12:04 AM
95NOSvette's Avatar
95NOSvette
Trickflow (from summit) makes a full set, but from what I remember they were kinda pricey..... also call www.thunderracing.com , they had several high quality gasket kits all packaged together for guys doing a cam swap, heads and cam swap, Ect.........Also, I Just figured I'd mention it incase you were unaware, In the future if you decide to change your head gaskets, you have the common option of going with a little thinner head gasket to bump your compression up a little over your 10.8 or so(if you wanted), and even more importantly, improve your quench......the common head gaskets to achieve this are the Impala gaskets which are 29thou thick..and the Mr gasket 5716's that are 26thou thick.....the felpro gaskets are about 39-40thou thick, and the factory gaskets are around 50thou thick.
To LT4 Gaskets?
