My '89 Climate Control is stuck on 90 degrees. The "Cool" temperature switch will not work therefore I have either heat @ 90 or nothing @ OFF. It has worked before because when I bought the car it was working but I messed up and raised the temperature with the "Warm" button but couldn't get it back down.
Any ideas on what I need to do here? Can the "Cool" button be fixed to work?
Do I need to replace the Climate Control Unit? If so, where is the best place to get one ? Mid-America, Ecklers, Last Detail, etc? How much does one usually run?
Thanks so much for any help in advance. It's 90 degrees outside here in S.C. so I need some A/C.
