zz4 vs zz383?
Old Apr 20, 2006 | 11:38 AM
vader86's Avatar
vader86
Originally Posted by 4Ever21
Would a 427 even fit in a C4?
you can shoehorn it in
fusionr's Avatar
fusionr
check out this set up for your 350CI engine http://store.summitracing.com/partde...5&autoview=sku
or you can go with a complete custom engine from http://www.speedomotive.com/
Old Apr 20, 2006 | 11:39 AM
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by nelson84
Most of the articles are from old Vette and Corvette Fever magazines when they were good.
If I can figuire out my scanner I might be able to post them and figuire out how to send them to that photobucket thing.
sounds good to me!!!!!!!
Old Apr 20, 2006 | 11:41 AM
88BlackZ-51
Lets get these article's scanned.
Old Apr 20, 2006 | 04:02 PM
Zix's Avatar
Zix
Would a 427 even fit in a C4? I know the LS7 would but its a specially designed 427.
There are quite a few GenI 427 SBC engines out there that would fit perfectly into a C4. The biggest SBC engine I know of is a 454 put out by World Products, but I beleive that one uses a tall deck which might cause hood clearance issues in a C4. Though I may be wrong about that, it's been a while since I've seen anything about it!
Old Apr 22, 2006 | 11:33 AM
Edmond's Avatar
Edmond
Originally Posted by vader86
In terms of what? power potential?
Fastburns are well beyond the ZZ4 heads, which are the same as '113 88-91 heads. No question which will make more power.
210cc runner vs 163cc runner, unported.
The question is whether the heads are too big for SR.
I've read that the FB heads are capable of supporting 500 HP and need no further porting.
Are the FB heads too big for a TPI system?
What happens if you put a TPI system on top of a ZZ383? What will that do to the powerband of the motor?
My experience with the 113 heads is that they have poor casting. There are burrs and dings in the casting, which I thought was careless and low quality. Are the FB heads of better casting and machining quality?
Old Apr 22, 2006 | 04:39 PM
88BlackZ-51
I have read plenty of articles with a stock tpi engine block with a zz9 cam and heads tpi big runners and intake and chip and headers and pulleys run low 12's so I would think a 383 would do better than that so why would low 12's be a stretch with either engines?
any luck with those articles???
Old Apr 22, 2006 | 05:27 PM
Edmond's Avatar
Edmond
What would a TPI on top of that ZZ383 do to the powerband of the motor?
The ZZ383 is rated for 425/460 but that's with a carb. What kind of numbers would a fully ported TPI system have on the ZZ383?
Old Apr 23, 2006 | 03:21 AM
nelson84's Avatar
nelson84
April 96 corvette fever (Intrepod tuned port)
TPI Specialties cold air package
52mm TB
ZZ9 cam
large tube runners
ported plenum
modified mass air sensor
CNC ported heads
accel manifold and headers= 12.3 1/4 at 112 mph
Old Apr 23, 2006 | 04:20 AM
Fubar569's Avatar
Fubar569
don't even need one of those...don't ask how i know...
the motor fits physically with no real mods. if you use a single groove v-belt crank pulley you don't even need to move the steering rack forward. i did so however to fit the black mountain precision cog drive system. certain oil pans do not require you clearance the crossmember (i have a high capacity hamburger racing pan - clearancing needed), and if you run a 6.75" balancer you should have no issues with that. the HVAC box will need to be swapped with a ZR1 unit or modify the stock cover. other than that, it's a pretty much direct drop in. engine management is another issue. i'm going straight carb. others have gone stand alone MPI, FAST, or with one of the holley units. either way, it'll friggin scoot.
oh...transmission will need to be heavily beefed up unless you are a ZF6 6 speed. dana 44 probably cryotreated at a minimum for rear end.
gauges probably won't work depending on if you can swap over your sensors. i plan on swapping over my oil pressure and oil temp, along with coolant temperature. my speedo will still work due to it drawing directly from the VSS and going to the dash before the ECM and actually my tach should theoretically work as well, but i'll probably go aftermarket tach anyways.
so yeah...piece of cake...lol
Old Apr 23, 2006 | 11:24 AM
vader86's Avatar
vader86
Probably could handle over 500.
Yes, they are huge for TPI, and I believe too big for SR.
Choke the hell out of it, it wont make anywhere near 425. You'll probably be lucky to get 375 with a stock TPI on it.
You get stuff like that on all mass-produced heads, FB's are a bit better though.
Old Apr 23, 2006 | 12:01 PM
Edmond's Avatar
Edmond
Fubar,
That sounds like a lot of work!
Vader,
What would the torque numbers look like? The main thing I'm interested in is torque. I'm not going to use the stock TPI system. I'll probably go with the TPIS Big Mouth with ASM runners or the Edelbrock system.
Old Apr 23, 2006 | 12:33 PM
  #33
vader86's Avatar
vader86
Torque would probably be around 400 at the crank, but at a lower rpm that its rated.
Its also rated with headers.
Old Apr 23, 2006 | 01:03 PM
  #34
Edmond's Avatar
Edmond
400 torque could also be done with the ZZ4 but at a higher RPM, right?
Old Apr 23, 2006 | 01:09 PM
  #35
Pete K's Avatar
Pete K
Generally speaking,
Spending money for cubic inches are well worth it.
Old Apr 23, 2006 | 01:17 PM
  #36
vader86's Avatar
vader86
400 torque could also be done with the ZZ4 right?
I doubt it. Its cam is too similar to the stock cam.
