CHECK OIL LIGHT QUESTION
Old Aug 20, 2001 | 11:33 AM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default CHECK OIL LIGHT QUESTION
Just changed my oil and now the "Check Oil" light is lit. What do I do to get this turned off? Does it require a tool that the dealership has, or is there a simple trick to it (like on Chevy trucks)? Thanks!
Old Aug 20, 2001 | 11:59 AM
Fang S-289's Avatar
Fang S-289
Default Re: CHECK OIL LIGHT QUESTION (365ZUM)
If you typoed and it's the "Change Oil" light that's on, there is an easy reset for it. If you need that procedure, E-mail me & I'll send it to you. If you did not typo and it's the "Check Oil" that's on: Try checking the sending unit. I believe it's on the left side of the oil pan. You may have inadvertently loosened or disconnected the wire attached to the sending unit.
[Modified by Fang S-289, 11:00 AM 8/20/2001]
