Chrome Oil Pans
Old Apr 18, 2006 | 02:07 PM
GRX's Avatar
GRX
Default Chrome Oil Pans
I've heard that chromed oil pans have trouble sealing. Is this true? I'd like to have mine chromed but if its gonna not seal as well then I won't. Any input apprciated.
Old Apr 18, 2006 | 03:26 PM
bsmutz's Avatar
bsmutz
Default Chrome oil pan
Well, you heard correctly. What I've been told is that you want to roughen up the edge where the pan meets the block using sand paper. Make sure you use gasket sealer on both sides of the gasket. You also have to be careful you don't overtorque oil pans.
Old Apr 18, 2006 | 03:56 PM
Pete K's Avatar
Pete K
I think the big reason chrome pans leak is the fact that the pan itself(on the chrome aftermarket stuff) is cheap and of poor quality. If you chrome a factory pan, I would bet the odds of leaking go way, way down.
Old Apr 18, 2006 | 05:50 PM
bsmutz's Avatar
bsmutz
I don't think that is the case as I have seen some well made chrome timing covers that leaked, too. The chrome oil pan I bought in the past was cheap and didn't fit well enough to use. I am sure there are good quality ones out there as long as you are willing to spend the money. The problem is that the chrome is very slick and is hard to seal against. Chrome valve covers are the same way.
Old Apr 18, 2006 | 11:53 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Exactly, that's the whole problem. It doesn't matter so much if it's a cheap or a good one, you don't want chrome on the sealing surface. I bought a cheap chrome transmission pan because it was $20 and had a drain plug. I sanded the chrome off on the gasket area and it's been fine for 3 years.
To Chrome Oil Pans
