intake/carbed question
Old Apr 19, 2006 | 04:21 AM
steve1ph2's Avatar
steve1ph2
Default intake/carbed question
`90 carb conversion. i think that my intake choice might be the problem. i was able to wot the car tonight on the highway. i had the pedal on the floor and the car was slowly creeping up on 120 befor i let off. i guess it wasnt slowly we`r talking normal seconds i guess. but what has me puzzled is with the super ram i had on it befor i could hit 130-140 in no time with what seemed like half of a pedal left. the intake is an eldbrock torker2 with a holly 750 classic double pumper carb. p.s. i still hate the sr.
Old Apr 19, 2006 | 07:06 AM
88espo's Avatar
88espo
sounds like you have way to much jetting. Any smoke?
Old Apr 19, 2006 | 08:01 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Also something to look at...
I found on mine, that I was not getting "Full Throttle". I had to modify the bracket for the throttle cable, so it would open all the way.
Mine was to high and to close to the carb.
Old Apr 19, 2006 | 09:33 AM
MustangHunter's Avatar
MustangHunter
Default Hood Clearance
I was thinking about converting to intake/carb...any prob with hood clearance?
Old May 2, 2006 | 12:13 PM
427t-top's Avatar
427t-top
could be timing Steve...try 10 and 36 total(its a stroker, right?)
Old May 2, 2006 | 12:47 PM
Raidmagic's Avatar
Raidmagic
What convinced you guys to go to a carb as opposed to the FI intakes that are out there? Have you noticed any loss in drivabilty since switching over?
Old May 2, 2006 | 08:23 PM
HeaderDesign.com's Avatar
HeaderDesign.com
Originally Posted by steve1ph2
I think that my intake choice might be the problem.
Looking at your engine photo, your air filter size could be alot of the problem. Your carb will hate the topside vacuum. Use a 3"x14" filter with good clearance above the bowl vents, and metal top.
Also, you are using the worst street intake in history combined with a severely oversized carburetor. That carb is for 500HP+ large displacement street engines, or smaller displacement high-RPM engines. The idle system has a "race" calibration to keep rough idling engines running.
You might try a manifold/carb combo like this for sharp street performance:
http://www.holley.com/8121.asp
Look at this graph:
http://www.holley.com/data/Products/...le%20Plane.pdf
I had a 383CID with about that powerband that ran sharp as a razor under all operating conditions with a high-rise dual-plane and a 600CFM Holley vacuum secondary carburetor. It revved straight to 6500RPM no sweat, and got "good" gas mileage.
SBC 383's with well-prepared 200cc heads, 10.5:1 compression, hydraulic roller cam in the 230's, RPM intake and 750cfm vacuum secondary carb will make over 500ft-lbs and 500HP. This is about as much as you can realistically put to the street even with an excellent chassis like the Corvette.
Old May 2, 2006 | 08:33 PM
JackDidley's Avatar
JackDidley
A 750 Holley with vacuum secondaries works great on a 383. Ran one on a C3 for years. A double pumper may need some tuning but should be do able. Be sure and look at the timing as mentioned above. If you are using vacuum advance, disconnect it when you set the base timing.
That car should fly with the right tune up, good luck.
To intake/carbed question
