I like to put mid grade in. I think it pays for itself in the added gas milage and it runs smoother. in texas, premium is 93 octane, and i dont notice any difference with it.
When the fuel prices began to get near the $3.00 a gallon point (yeah, I know - which time) I decided to try a tank of 89 octane in my 1991 to see if there would be any noticeable differences. Granted, I did not have my laptop plugged up nor did I run a performance tuning program during this test. However, I do posses a highly sensitive and finely tuned Butt-o-meter. Within 15 miles of hyw driving I began to notice a marked lack of throttle response along with a change in exhaust tone (yes, the audio input is wet-wired to the butt-o-meter). The Vette also seemed to develop a slight off throttle hesitation in around town driving that as not present during the use of 93 octane fuel and seemed to require more of the right foot to negotiate some minor hills encountered during it's DD duties.
Overall the Vette felt and acted "sluggish".
It took almost a week to burn through the tank of 89 octane after which I have run through almost two tanks of 93 and all of the above noted symptoms have since disappeared.
Coincidence? Maybe, but I'll stick with the premium. It is Butt-o-meter approved .
I burn 87 in my LT1 & have no problems. I'm a Senior Citizen & drive like one . My car has 157,000 mi. & I imagine the wear lowers the BMEP's a bit. Plus I'm hard of hearing from Piloting Jets for 33,000 hours & can't hear the pinging if my Hearing Aid Batteries aren't fresh.
Being old has the advantage of blocking out all the things that annoy younger people.
This is my kind of gentleman. I want to be just like you when I get older.
Here is a direct quote from my original '92 owner's manual:
"Be sure the posted octane for premium is at least 91 (at least 89 for middle grade and 87 for regular). If the octane is less than 87, you may get a heavy knocking noise when you drive. If it's bad enough, it can damage your engine."
Tom Piper
As the above section from my owner's manual states, my '92, when stock, was designed to work with anything from 87 octane on up. I ran 87 in it with no problems.
Of course, there was not as much power because the ECM was retarding the timing to keep detonation from happening. That is why the text under my fuel door states that premium is recommended. It is recommended because most Corvette owners, especially when these cars were built, were more interested in perfomance, not cheap fuel.
I know a '93 owner that ran nothing but 87 octane for years with no problems.
Everyone has to decide what they want to run, but the bottom line is you won't hurt a '92 LT1 that is stock, like mine was, by running 87 octane in it.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Hot Rod 90
here's the breakdown i would generally go with:
'84-85: 87 octane
86-89: 87, or 89 octane max
90/91: 89, or 91 octane max
92-96 LT1: 91 or 92 octane
That's a good start. I like the "maximums" on there too. I would add that cars used mainly in higher elevations can go down a point or two safely. This fits in CFI's 85 octane. Although there are places in the midwest that sell 85 or 85.5 that aren't high elevation.
Does anyone know the reasoning behind this reduced octane requirement?
With gas prices going to thru the roof for no reason, my question to everyone is this. Do I have to run premium gas in the 91 like the owners manual and the little stickers say, or can I run regular grade gas in it? It gets much better mileage than either one of our trucks but I can't justify spending the extra 20 cents a gallon. To me that just cancels out the better mileage. I need to know if we can run the regular grade, because right now, the vert is just a conversation piece sitting in the basement looking pretty.
There is nothing in the 91 owner's manual that says Premium MUST be used. It says Premium Fuel Recommended
I use 89 octane mid-grade in mine, and it works just fine. I've run regular in it before, but there is just the slight hint of a knock when you put your foot in it. With mid grade, I can't tell a difference between that and premium.
Sorry about the pic quality...just ran out and took it with my phone.
From: The reason time exists is so everything doesn't happen at once
Originally Posted by Fuzzy Dice
Interestingly, below both phrases it is printed in French?...are they all like that or do I just have a Canadian honker?...
I believe that under Canadian law any item sold in Canada must have instructions in both English and French. GM was probably just cutting costs by using one sticker for all North American cars.
It is no myth. Granted, the lower octane gasoline contains no more energy, but the principle means by which octane retards detonation, is by slowing the burning process. The power exerted in a more concentrated manner, at the right time, can have more impact than if spread out over time, including times where it is less effective.
It isn't a matter of having more, it is a matter of using what you have to greater advantage.
Irregardless of the cost per gallon it is as you originally said, you don't want to pay the extra 10 cents a gallon difference. A 10 gallon fillup is going to cost you an extra buck ! Put the recommended good stuff in.
Sure at $3.00 gallon it costs $30, but at $3.10 it is only $31. No brainer !!
The sucky part is paying the base price in the first place.
Do what I did. Invest in VLO. They are an oil refinery company. Their stock has gone up over 20% in the past couple weeks !!! So let them raise the price. I am making more off the stock than it is costing me in gas !!!
My $0.02
An over reaction, in my opinion. There HAD to be more wrong with that tank of gasoline than a mere half a dozen points of octane. Octane only serves to suppress knocking. No semi-normal engine or better is going to ping or knock after 15 miles of highway driving. A steady cruise speed puts the lightest load possible on the engine, other than at idle, and it is under heavy loads that the engine pings, knocks, or detonates. The lack of throttle response, the change in exhaust tone, the hesitation, and the lack of power were not, all caused by a lack of octane. Water in the fuel, some other form of contamination, maybe, but all these ills did not spring from a lack of octane.
Lower octane gasoline is available at higher altitudes because the thinner air (lower barometer) contains less oxygen per cubic foot. This results in lower cylinder pressures, where detonation is caused by excessive cylinder pressures.
I can only speculate that the relatively high altitude and the lack of hills, allow the use of lower octane in some of the plain states.
This question always gets me going so pardon the rant, but it really just comes down to "do the math". Assume you drive 10,000 miles a year and you get 15 mpg. So that's about 700 gallons in round numbers. Assuming the premium is 20 cents a gallon more you are talking about spending maybe $150 a year more for the premium.
If that is a great concern then you should have gotten a Yugo instead of a Corvette. Moreover, if you can afford to have a Vette sitting in the basement without being driven (I assume you still have to be paying insurance), doesn't it seem odd to be worrying about a few more cents for premium gas??
Then there's what should be called "super premium" but often isn't, whether its at the pump or by many on this board. That would be 93 octane.
Your "average" LT1, with 10.5:1 compression, should NOT need 93 octane. Maybe that rare animal would because of poor build quality at the plant........
91-92 max; that's most all LT1's. Going higher is pizzing $$ away, and plenty at that. It has just about nothing to do with being "safe". Justifying 93 to one's self is like shooting at the bank account, blindly. As for that "safe" argument, you guys DO have a knock sensor, right????
The octane ratings here in CA have not been above 91 for quite some time now. About a year ago I experimented when the local Union 76 station was offering "racing" gas that was supposed to be about 100 octane. At the time it was several dollars a gallon more than the standard pump. I put in maybe 2 gallons of this and filled up the rest of the tank with standard premium. I have to admit that I felt a difference--the car was definitely more responsive. I'm not certain what effective octane I got out of this mix.
