Clutch Problem?
Old Apr 19, 2006 | 03:00 PM
PaintitBlack95's Avatar
PaintitBlack95
Default Clutch Problem?
When car is off it goes through gears fine like normal. But when it is on and I push in the clutch(all the way to the floor) it has to be shoved into gear. Not everytime just most of the time. Do I just need to adjust my clutch or is it a bigger problem? Its a 95 vette
Old Apr 19, 2006 | 03:10 PM
MarkBychowski's Avatar
MarkBychowski
Definitely sounds like the clutch isn't completely disengaging. Has it been getting worse?
There's no adjustment on the clutch since it's a hydrolic linkage. Hopefully, a simple fluid flush / bleed will cure it. Chances are it still has 11 year old clutch fluid in it. Worst case, it could be a seal going bad in either the master or slave cylinder. If that's the case, you'll need to find the leak and replace the culprit.
Old Apr 19, 2006 | 03:24 PM
500hp's Avatar
500hp
Check your clutch master cylinder reservoir. It is underneath the ECM and brake booster on the firewall. If the level is down below the orifice at the bottom of the reservoir, then it is getting low. Also check under the car for brake fluid (that's what the hydraulic clutch uses for fluid) under the driver's floorpan or on that same side of the transmission. There will be a small stainless steel braided hose in this area, so check it for wetness or breaks/cracks where it curves around.
If everything checks out okay, now may be a good time to drain the tranny fluid, inspect it, and refill with new. Check tranny tailhousing, C-beam, and tunnel for leaking tranny fluid.
Old Apr 19, 2006 | 03:34 PM
PaintitBlack95
Yeah it has been getting gradually worse. I am assuming that leans towards a leak. I will check out all the above. thanks for the input
Brian
Old Apr 21, 2006 | 12:26 AM
PaintitBlack95
ok, so the clutch line isnt wet or doesnt appear to be leaking and I cant find any problems with the slave or master cylinder. But the fluid level is extrememly low. So anyway here is my problem, kinda embarressed to even post this but I unhooked the computer and got it outta the way and when I tried to take the cap off the resevoir to refill it I couldnt get it to budge. Is there a trick to it or is mine just stuck? gonna try something different tommorrow but I couldnt get it off with just my hands
Old Apr 21, 2006 | 02:24 AM
MarkBychowski
No trick -- they're just a pain to remove. Just make sure you hold the plastic tank when you use a lot of force otherwise you could break the mounts.
Old Apr 21, 2006 | 12:21 PM
PaintitBlack95
thats what I figured, I have problems even getting one of my hands on it much less both in there lol
Old Apr 21, 2006 | 12:48 PM
Jerris's Avatar
Jerris
If there are no external leaks it looks like the seals in the master are starting to go, or there is air in the system.
Old Apr 21, 2006 | 01:39 PM
Wildcat1's Avatar
Wildcat1
I had the same problem checking mine recently, I finally got it off by putting on some leather gloves and making sure I rubbed the cap down good with a papertowel. I also removed the ECM mounting bracket in addition to the ECM.
Old Apr 21, 2006 | 02:48 PM
TorchRedRob's Avatar
TorchRedRob
Also check Bill B's site for a great write-up on clutch actuator cylinders, and how to diagnose if it's your master or slave cylinder (or both) acting up:
http://zfdoc.com/clutch_hydraulic.htm
You can replace both the master and slave cylinders and get appropriate GM clutch fluid from Scoggin Dickey for less than $250.
About to do this myself on my 95. . .
Rob
Old Apr 21, 2006 | 05:00 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
A leak in the hydraulic line or air in the system will first result in a very soft pedal. I would start by changing the tranni fluid at the same time keeping an eye on the fluid level. If it drops you no doubt have a leak.
To Clutch Problem?
