PP2 help
Old Apr 19, 2006 | 08:50 PM
black_89_vette's Avatar
black_89_vette
Default PP2 help
For the life of me I can't remember how to run this friggin program. I used to have it up last year but didn't use it much. Now after a new computer and a new download ( I-PP2Win2.35.exe) whenever I try to put in a chip and use setting 27sf512 (cuz that's what it says on the chip) and it takes forever to blank check and verify device.
When I select move device to buffer and save buffer, when I open it up in Tuner Pro with a 6E.xdf definition file, it shows crazy numbers like base timing at 90 degrees and stuff.
Do I have incompatable versions of software or what am I missing here? I even tried to load an old .bin file onto a blank chip and it's giving me different values than my old .bin file.
I'm about to lose my mind. Please help.
Old Apr 22, 2006 | 09:28 PM
black_89_vette
anyone?
Old Apr 22, 2006 | 10:18 PM
Morley's Avatar
Morley
Sounds like a software conflict.
Old Apr 23, 2006 | 02:28 AM
black_89_vette
I used to use I-PP2Win2.00 . Maybe it's because I have an upgraded version of that and an upgraded version of Tuner Pro .
Could it be that since tuner pro only wants .xdf files that I'm not finding the correct ones?
Would using 6E (for my 89) while looking at a .bin for an 87 result in weird numbers. Maybe I need to find a .ecu or .xdf file for an 87?
Old Apr 23, 2006 | 03:43 AM
Morley's Avatar
Morley
Yes, the $6E is 1989 code, 1987 used $32B.
Old Apr 23, 2006 | 01:59 PM
black_89_vette
Is this the correct place to ask for such a file? Or is that a big no no?
If you have that file, could you post it?
Old Apr 23, 2006 | 05:10 PM
Morley's Avatar
Morley
Can't post it here, but I can E mail it to you.
Old Apr 24, 2006 | 03:29 AM
black_89_vette
If you could that may help my hair's life as I seem to be pulling it out.
jerrymilne@canada.com
Old Apr 25, 2006 | 05:27 PM
YoMilkMan's Avatar
YoMilkMan
Homer click on start run, regedit, click on find search for EPROM. Find folder delete it. close that out the C:\program files \eprom delete folder from there. reboot computer then reinstall that might fix you up
Old Apr 27, 2006 | 02:54 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Heres what you should do with the PP2.. Drop kick it across the yard. They are trash.. plain and simple.... Don't believe me? I'll send you a picture of my PP2 graveyard.
Old Apr 27, 2006 | 05:06 PM
black_89_vette
Hehe, I am not sure if for some reason I'm not doing things in the correct order or what it is. I have rarely used it but when reading things off his chip I'm getting crazy readings like 90 * base timing.
Is there a chance that the chip could have gone bad? Like maybe had contact with a magnet or somtehing like that?
To PP2 help
